Is GDI by definition only....
  • Hansoon
    • Sep 2007
    • 3381
    .....for USB connection or are there also GDI drivers for TCP/IP?
    Hans
  • blaze2000
    • Sep 2010
    • 232
    Re: Is GDI by definition only....
    GDI really isn't a driver at all. When you use GDI you are bsically using Microsofts system to render graphics as opposed to the manufacturers software/ driver.
    So your answer is no it is not just for USB, it can be used in conjunction with TCP/IP.
    • TheOwl
      • Nov 2008
      • 1732
      Back in the day when Di1611's were new, we had a lot of problems with the PCL board in the machines. What we did to get around that was to disconnect the PCL board and install the GDI drivers and print to the device via the network.
      It exactly the same as printing to any other printer whereby you would setup a port for 9100 and print away.
      Just like Blaze2000 mentioned, it is a Microsoft thing used for transmitting images to printers and monitors.
      Now I also believe that the MS XPS drivers have now replaced GDI as far as printing is concerned with XML being the new standard.
        • 23006
        Kyocera drivers have a checkbox buried somewhere to enable GDI printing. It's a useful feature when you've got a print document with various embedded images, and it's not coming out exactly the way you'd like. =^..^=
        • rthonpm
          • Aug 2007
          • 2853
          Unfortunately, there are network drivers for GDI printers. I have a few customers who made the poor choice of buying a CLJ 3600 for use as a network printer. It seems to depend on the operating system as to whether network drivers are supported.
