Kyocera 300ci print driver issue
  • alpha-omega tech
    • 80
    When installing the KX print driver to a network or on my laptop with a crossover cable(so I eliminate the network completely). The driver when installing will not discover the copier, so I do a custom install and when I am done installing the driver I try a auto config so the options on the copier are detected. I then get a message The selected TCP/IP port is connected to a network printer that does not match the current print driver. In order to use the auto configure feature, select a TCP/IP port that matches the current driver. I can ping this IP and bring up the command center. A universal driver will install and config and the KX driver even though it won't auto configure it will print. There is only one driver and and ip address so there is no confliction. The driver is taken from the Kyocera web site. Any ideas or has anyone run into this.
  • Dougtech
    • Apr 2011
    • 113
    Re: Kyocera 300ci print driver issue
    This will occur if you download the driver for the wrong model# - i.e. a KM-3050 driver will not find or auto-configure a KM-4050 or KM-5050, though the driver will print.
    that is the only time I have had that issue myself
    • eddie110171
      • May 2012
      • 133
      When connecting directly to the copier did you manually configure the TCP/IPv4 connection? ie. different ip address on the same network (192.168.1.X) only last number changes, and same subnet. I aways set the gateway too but it does not make a difference, just habit.
      • Redarmy
        • Sep 2011
        • 25
        Check if its the KM not and doesn't have the CS in the driver name
        • justinduckett
          I am having the same exact issue on two 300ci's, I have re-done the firmware and have also ran a sim 21. plus have tried both drivers including the cs and km and both have the same outcome. I am going today to replace the whole print board to see if this will resolve the issue.
          • blsquires
            • Nov 2008
            • 342
            I have had a few problems using windows explorer to down load drivers .they install with bits missing and command centre not working properly.
            I now use firefox to download drivers and it seems much more stable.explorer doesn't come up with errors it just will not download correctly .
            I don't know if this is any help .
            • shaqmut
              • Dec 2012
              • 5
              hello
              try also to update with new firmware
