KM - Active Directory Authentication is intermittent
  • cadkins
    • 34
    We have customer that has several different models of KM. We have it set up to authenticate from the copier as well as print via AD. They are running Server 2008r2.
    It is very intermittent but the user can walk up, try to log in and it fails. Try again and it works.
    Same with printing. User can go to the properties and hit "Verify" and it fails. Close out and try again and it works.
    Sometimes if the user fails, it will continue to fail for a while and then start working a few minutes or an hour later.
    The time zone is set correctly as well as DLST is set.
    Since I know next to nothing about AD, I have no idea where to go from here. Any suggestions?
    Looking through the KB didn't give any results that looked like it would help
    Thanks in advance!
    -Curtis
  • rthonpm
    • Aug 2007
    • 2859
    Re: KM - Active Directory Authentication is intermittent
    Couple things to check:
    1. Is the machine itself on the domain and, if so, is it listed within the correct group?
    2. Is the firmware for every model up to date?
    3. Any change if the users try entering their user name as domain\user?
    4. Are the machines using the same DNS server(s) as the domain controller?
    • cadkins
      • 34
      Thanks for the quick reply.
      I'll just respond to them by number.
      1. Do you mean, is the domain listed in the machine? And I am guessing by "Group" you are referring to within AD?
      2. Yes
      3. No
      4. Yes
      Thanks again!
      • TheOwl
        • Nov 2008
        • 1732
        What is the network speed set to?
        Intermittent problems like this can be caused by switches and other little stuff. Try slowing down the network speed of the copier and see if that helps.
          • 23008
          Could the DNS be a little slow or inconsistent? You might try the IP address for LDAP, rather than the hostname. =^..^=
          • kronical
            Kronic Copier Ninja
            • Nov 2009
            • 230
            Turn on sntp and set the ntp server address to the address of the domain controller. Even though your timezones and date/time are set there will be a few second discrepency between the two. During the period the times are not synced you will fail authentication. This will sync to the dc.
            • RRodgers
              • Jun 2009
              • 1947
              Goto a desktop and ping the copier for a while and watch it, then ping another desktop and see how that one does. If it's jumping around a lot I would check the router next. Does it work fine in the morning and not so great after everyone logs in to there computers and starts checking email/facebook/youtube.
              • TheOwl
                • Nov 2008
                • 1732
                Active Directory will allow for a time difference of +-5 minutes of the domain controllers. Seconds don't really count unless it is 5 minutes and 1 second.
                Setting the copiers to use the DC's within the network is still a good idea regardless of the installation.
                • cadkins
                  • 34
                  yes, they are set to the DC for the NTP server.
                  we did watch it for a while even when trying the verification via print driver. It was very consistent.
                  We have tried both the host name and the IP for the external server but we are using AD not LDAP. There are really no settings besides the time, the AD server and the domain that needs to be done for it to really work in a normal situation.
                  I am actually wondering if they are having a caching problem on the server. They don't see this intermittent problem from the computers since that info is cached. I was under the impression that the print driver would cache the settings as well but since that information is going back through the copier, it may not. Anyone know if it does?
                  Thanks for all the suggestions and help!
                  • rthonpm
                    • Aug 2007
                    • 2859
                    2. Yes
                    3. No
                    4. Yes
                    Thanks again!
                    I meant to ask whether or not the copier is actually set up as an object on the domain controller. Sometimes setting the machine as an object that the DC can actually recognise can help alleviate connection issues. The trick then is to also make sure that the copier is in a group that doesn't get group policies and such pushed to it, like a special purpose group.
                    Another thing: is this a subnetted network or built on VLANs?
                    • cadkins
                      • 34
                      OK, I just wanted to make sure i understood you. Yeah, the printers are set within a group in AD. I am not sure if it is a special purpose type group but I can check.
                      They are not on a subnetted network but it is pretty large. For their remote locations they might be on a VLAN but I will check that as well.
