Has anyone out there experience the dropping off having to reboot every morning to get the unit back on-line or on the network? We have a couple of C451's that every morning the customer has to reboot in order to get them back on the network. We have the switch and copiers at 100 full duplex.
Cisco switch 6500 / Bizhub c451 Dropping off
With the older Minolta print controller, specifically the Pi......ok forget the model number, used on the Di251 of which I had about 50 connected, the controller could lock up to the point where a power recycle wouldn't work. Had to fuss around with resetting the factory defaults and firmware loads to get them back to working condition.
samarrattan
Problem is Power over Ethernet
This has caused problems for all the Konica Units we ever had (On a Cisco Catalyst 6500). 7145s, C450, C451s. You can have the Network Admin turnoff PoE on the relevant ports, (but that still caused problems for use.) I ended up using Netgear switches (stuck to the back of the units using velcro) to clean out the cisco garbage and clean up the traffic going to both the emperon and the fiery.
Problems went away.Comment
451 dropping off
i have had this a few times, couldnt get my head round it to start with. removed hard drive the lot. Finally sorted it out You need to upgrade the firmware with the latest available it called R5. that will fix it for sure. MattComment
