Canon IR 2525 Print n/w stopped pinging. (Customer says after bldg. power failure)
  • Doug James
    • Jan 2012
    • 935
    Won't print from work station, won't ping, Changed some network cables and it started working, Then messed with the cables again (ran through power surge box) and it quit working (Put back, still n/w). Everything on the controller board seems to work... fax etc. (Red led is on).
    • 23006
    Re: Canon IR 2525 Print n/w stopped pinging. (Customer says after bldg. power failur
    I'd connect my laptop to the printer via crossover, then start a continuous ping and let it go for a few minutes. If it stays connected, and you can print from your laptop, you're done. It's a network issue. =^..^=
    • charm5496
      • 2387
      it still might have surged power through that network port and fried the circuit. I would do as blackcat suggest and test with your laptop, but if you still have the same issues I would prepare the customer for a charge. Not only for your time spent, but for the board and future time spent repairing it.
      • mramlawi
        • Jul 2011
        • 838
        I agree with blackcat & teckat also so coo eect it directly to laptop then try
        Distinguished road makes you jewel in rough
        • Doug James
          • Jan 2012
          • 935
          THANKS EVERYONE SOOO MUCH FOR YOUR HELP !!!Will do.. (I am not much of a computer tech and your feedback is so helpful...
