toshiba 232 scan to email
  • Fattdaddy
    • Aug 2012
    • 38
    Machine asks for username and password when you
    select scan to email.SMTP client set up has no
    username or password entered.Where else could this
    be coming from?
  • TheOwl
    • Nov 2008
    • 1732
    Re: toshiba 232 scan to email
    The machine has been setup for SMTP Authentication which requires users to login for the right to be able to scan to email. This also makes the machine send the email from the email address of the user that is logged in.
    To disable this feature, go into the web interface of the machine, log in as the administrator, go to the email settings and then down the bottom, disable the SMTP Authentication.
    • Fattdaddy
      • Aug 2012
      • 38
      It is set to disable. I hope someone has something else. Thanks for the suggestion.
      Originally posted by TheOwl
      The machine has been setup for SMTP Authentication which requires users to login for the right to be able to scan to email. This also makes the machine send the email from the email address of the user that is logged in.To disable this feature, go into the web interface of the machine, log in as the administrator, go to the email settings and then down the bottom, disable the SMTP Authentication.
