USB connection from machine to router
  • BLADE
    former propeller tester
    • 478
    Is it possible to print to Ricoh MP2000Le (no print option)via wireless router then usb to machine
  • rthonpm
    • Aug 2007
    • 2857
    Re: USB connection from machine to router
    If there's no print option installed, how exactly are you planning to get it to print anything?
    • TheOwl
      • Nov 2008
      • 1733
      Lets forget the "no print option" for a mintue...
      If your wireless router has a USB port on it which is for printing or an external HDD, then yes you can. The router acts as a print server so to speak which redirects print data to the USB port.
      In this case, you will need to setup a printer locally on your computer and setup a new Standard TCP/IP Port (for PC) or HP JetDirect Socket via IP Printing (Mac) and use the IP address of your router as the machine won't have one. From there just install the driver as per normal and you should be right to go.
      • BLADE
        • 478
        Firstly am asking on behalf of another tech, the device comes with a standard print controller. Thanks owl will pass that on
        • habik
          • 2014
          Would this setup sort of speak work as wi-fi printer?
          Can I use any router, like for broadband used at home?
          How about USB 2g Dongle and printing over small LAN without router,just switch is that possible? I just posted a thread.
          Firmwares HERE
          • TheOwl
            • Nov 2008
            • 1733
            You could also try one of these as well. Basically think of it as a media converter which changes Wired LAN to Wireless LAN.
            WNCE2001#
            Two options come with the adapter:
            1. Power via USB port (which most copiers are capable of)
            2. Power via standard General Power Outlet (for copiers without USB ports)
            I've used them on a couple of machines previously and haven't had any issues.
