Unable to install printer. The print processor does not exist. Fixed
  • df3036
    • 109
    Fix that worked for me. Copied from some site on the net....
    Windows error when installing driver. "Unable to install printer. The print processor does not exist"
    I copy the print processor files from another working machine with the same architecture as the one with the problem (x86 or x64).
    Step 1: Stop the Print Spooler service.
    Step 2: Copy all files and folder on working system under C:\Windows\System32\spool\prtprocs\x64.
    Step 3: Make a backup on the problem system of the files listed under the C:\Windows\System32\spool\prtprocs\x64.
    Step 4: Paste the files that you copy from the working system into the folder un the problem system.
    Step 5: Start the Print Spooler service.
    Try connecting or installing your net printer and it should work now.
    Dave
    Original site:
    Windows 7 Enterprise -64bit.  I am able to install HP LaserJet printers but no virtual printers.  I can not load Print To OneNote or the Windows XPS Printer.  I have also tried to load several PDF printers and none of them work.  The error I keep gettig …
    Kittens give Morbo gas.
    A+, Network+, Server+, PDI+
  • Rakesh
    • May 2012
    • 72
    Thank you.
    Sent from my Samsung Galaxy S GT-I9000 using Tapatalk 2
    View Life As A Continuous Learning Experience...
