Konica Minolta C450 Scanning Setup
  • AlSyed
    NewBee
    • Aug 2010
    • 41
    Hello Fellows,
    First of all please accept my best wishes for the New Year and I wish we all stay Healthy & Wealthy in the coming year.
    I replaced NVRam in a KonicaMinolta C450 after Power failure. Now I am trying to setup Scanning. In Scan I created 4 SMB accounts and 1 email account.
    (Name) -- FAXINBOX
    (Index) -- ABC
    (Checked) Main
    192.168.0.150 (Ip address of Server)
    hp_Server\Z:\Scanner\faxinbox (File Path)
    roop (User ID)
    The problem is I dont see any of them on Copier Screen (When Press Scan) whereas when I logon through computer as (Public or Administration 12345678) I see them.
    Help will be very much appreciated.
    Tnx
  • MFPTech
    • 486
    Re: Konica Minolta C450 Scanning Setup
    Happy New Year to you too!
    Set that info up from the control panel of the copier and see what happens.
    I always try to browse from the copier side and use a laptop/computer only if i have to.
    Cheers,
      • 22995
      Are you pressing that button on the scan screen that says "Addressbook"? =^..^=
      • JSC
        Gimp
        • Dec 2006
        • 618
        In the web browser tick the the box (main I think) after the name, where you set the scan details. It should then appear on the main scan screen in the copier.
        The gene pool could use a little chlorine.
        • Mr Spock
          Vulcan Inventor of Death
          • Aug 2006
          • 2064
          "hp_Server\Z:\Scanner\faxinbox (File Path)" is an invalid file path. you need to find out what hp_server\z: represents.
          hp_server should be the same as ip address
          since z: is a mapped drive then you need to see what it is.
          z: is probably something like "data\users\" or "company\data\users"
          • AlSyed
            NewBee
            • Aug 2010
            • 41
            Dear Fellows, Many Many Tnx for the replies,
            (blackcat4866) I have pressed Address Book as well but did not see those Tabs.
            (JSC) Main was checked.
            Mr. Spock) hp_server is the name of the Main PC serves as Server, Then Z is the drive, Shared folder is Scanner and the another shared folder inside the scanner folder is faxinnbox.
            If possible please advise of the right path with these details.
            In the meantime I try to Uninstall and Reinstall the HDD and try to reformatt but got error. Going to replace the HDD and then will try again.
            • ruben
              The New Guy
              • Oct 2012
              • 1203
              If the drive Z: is mapped, you need to know the path which it points to. Forget about the Z: drive. On another computer on the network, or the server itself, check My Network Places/Network, navigate to the server and double click to view the folder structure. If you folder is visible then you can use \\hp_server\address\to\folder\faxinbox.
              I will say again: Forget about the mapped drive.
              • Chameleon
                • Nov 2011
                • 200
                After you replaced the NVRAM, did you do a logical format to the HDD?
                I had one where I could not change or edit the addresses after a firmware update, even logged in as admin at the copier or from pagescope. I had to turn off the accout track, format, then I could add and edit addresses. GL
                The chance that higher life forms might have emerged in this way is comparable to the chance that a tornado sweeping through a junkyard might assemble a Boeing 747 from the materials therein. -Fred Hoyle
                • AlSyed
                  NewBee
                  • Aug 2010
                  • 41
                  Respected Friends, Changed the HDD and made the changes like under. Many Many Tnx to all the Wise people and specially Ruben.
                  Added \\ in the begining of the file path.
                  ENETRED PASSWORD AS WELL
                  (Name) -- FAXINBOX
                  (Index) -- ABC
                  (Checked) Main
                  \\hp_Server\Z:\Scanner\faxinbox (File Path) ADDED \\ in the begining of file path
                  roop (User ID), ENETRED PASSWORD AS WELL
