W7 SMB Scanning
  • Hansoon
    • Sep 2007
    • 3385
    W7 SMB Scanning
    W7 SMB Scanning
    OK, I know there are a zillion threads about this issue here but I'm still not able to let SMB scanning work with W7 (XP no problem ofcourse). All silly W7 Username and Authentication requirements seems to be set correctly. Any hints or instructions how to get this working? Its mainly about KonicaMinolta BH 350 B&W machines. What did I left out?
    My set up with Scan-FTP works fine but customer insists using SMB scan though.......
    Hans
  • JR2ALTA
    • Feb 2010
    • 2033
    It could be a sharing issue because of the workgroup setting in the advanced window of the sharing center.
    why do you think it's login? The 350 has no real diagnostics.
    Of course there's the myriad of domain issues if it's a domain environment
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      Re: W7 SMB Scanning
      Make sure you check everything.
      Check that the folder is set to shared through a PC on the same network.
      Check the folder you are scanning to has the correct permissions set, you may need to allow everyone to read & write. Make sure the folder is shared using Advanced Sharing and not just through Share...
      Try adding a domain qualifier to the username, e.g. domain\username or username@domain.
      Try connecting directly through IP, then move onto hostname. Preferably use the hostname.
      Some devices require you to lower the encryption to 40/56-bit, by default Windows 7 is on 128-bit. (This can be done in Control Panel -> Network & Sharing Center -> Advanced Sharing Settings).
      You could also try lowering the NTLM authentication in Control Panel -> Administrative Tools -> Local Security Policy -> Local Policies -> Security Options to Send LM & NTLM - use NTLMv2 session security if negotiated. Also, with Network security: Minimum session security for NTLM SSP based (including secure RPC) clients, untick Require 128-bit encryption.
      Some devices have problems with Windows Live Essentials and similar products, these may need to be uninstalled.
      This usually fixes most devices, your results may vary. If all else fails, it may be a firmware issue.
      • Hansoon
        • Sep 2007
        • 3385
        Re: W7 SMB Scanning
        I meant in W7. (edited my thread now)
        Hans
        • Hansoon
          • Sep 2007
          • 3385
          Re: W7 SMB Scanning
          I don't get it. Are there so many varieties of W7?
          (BTW: Is there any good argument against FTP scanning?)
          Hans
          • pfinn10
            • Jun 2010
            • 46
            Re: W7 SMB Scanning
            havent used a 350 so not sure if it still has it, but if you goto job details. Does it tell you what the error was? login error? server connect error?
            • Hansoon
              • Sep 2007
              • 3385
              Re: W7 SMB Scanning
              OK, went there. SMB-Scan on my W7 Notebook works. However with the same settings it doesn't work with their W2008 R2 server.
              As a workaround I installed Scan-e-mail for the moment. The reason their IT-guy doesn't want Scan-FTP seems to be a security issue.
              Thanks for all of your input guys.
              Hans
              • emujo
                • Jun 2009
                • 3009
                Re: W7 SMB Scanning
                Hans
                My main issue with FTP scanning is when a tech gets lazy and scans to the IP address versus the host name, IPs change, and it's a call back that's not necessary, also, the FTP utility has to be running on the host, again, some users accidently turn it off, and I don't like running any extra services on a server...but back to your SMB issue...by default, Win 7 (and maybe 8) has SMB file and print sharing turned off. This will be a brick wall you won't get through..Firewall setting can block communications also. Win7 home edition (not too many out there except in the private home setting) doesn't support SMB scanning (I believe..someone correct me if I'm mistaken, except for ZAZA or TinnyJay as they are tools). Hope this helps. Emujo
                • JR2ALTA
                  • Feb 2010
                  • 2033
                  Re: W7 SMB Scanning
                  there is special firmware is the server is also the domain controller
                  • Hansoon
                    • Sep 2007
                    • 3385
                    Re: W7 SMB Scanning
                    In case one wants to turn it on, how to do that?
                    Link doesn't work
                    except for ZAZA
                    Did you really mean "ZAZA" ???
                    Hans
                    • ruben
                      The New Guy
                      • Oct 2012
                      • 1203
                      Re: W7 SMB Scanning
                      Control Panel -> Network and Sharing Center -> Advanced Sharing Settings -> Find the current profile (most likely Home or Work) -> Turn on file and printer sharing.
                      • Hansoon
                        • Sep 2007
                        • 3385
                        Re: W7 SMB Scanning
                        Thanks Ruben. Next time I'm in Bristol UK I'll buy you a nice pint of lager in the pub.
                        Hans
                        • emujo
                          • Jun 2009
                          • 3009
                          Re: W7 SMB Scanning
                          Link doesn't work
                          Hans
                          I didn't see the MFP was a 350 until later, the firmware adds NTLM ver1/2 and allows you to scan back to a domain controller or a "NAS" (linux based drive). I know the firmware was put out for the 362 series, but I'm not sure if it was released for the 350. Either way, w/o a KM account you're gonna have to beg someone for it. We try to upgade these old MFPs before they start adding win7/server2008 etc..Emujo
