kyocera mita/copystar 5035
  • rbell12
    • Aug 2006
    • 83
    is it possible to use nec 5035 firmware to upgrade?
    • 23009
    Not Here Nor There
    Here's my not-here-nor-there-answer:
    The same firmware is used on both kyocera and copystar machines. I think it's likely to be the same.
    But if we're wrong you'll get to buy all new ROMs.
    • knightfall
      • Jul 2006
      • 633
      gotta be careful sometimes even the right firmware can cause the controller board to fry, had it happen to me twice with the 5q firmware for 2 separate km 5035s don't know why but it happened for these 2 copiers.
      Get your facts first, and then you can distort them as much as you please.
        • 23009
        Yeah, I've corrupted three ROMs in the last two months (two CS-5050s and a CS-2560). The funny thing is I used the same CF, same firmware, successfully on the new ROM's. Who knows what corrupts these things........
        • copygirl
          • 75
          Gotta upgrade all firmware at one time. You do the print system with memory card at print system. Upgrade machine at slot inside upper right cover. Just take out the 3 screws and the slot is towards the rear. Can you get all the firmware files? Let me know if I can help you.
          Ginger
          • rbell12
            • Aug 2006
            • 83
            copygirl
            do you know the checksum for the latest firmware to upgrade our machines? printer firmware is 146.06 and another machine is 146.09 and the other one is 146.10. these are the machines that we currently need to know if they need upgrade. if so can you e-mail us the current files? we would appreciate any help you can give us. also are these km files or nec. our machines are all km.
            • copygirl
              • 75
              Sure I'll send them to you. They will all be zipped files. Format the memory card on the computer for the machine and the print system can be formated at the print system. Do you have the procedure? I can send it with the files.
              Ginger
              • rbell12
                • Aug 2006
                • 83
                copygirl
                thank you for what you have already sent. yes, if you could send the install procedure, that would be great, as we have no documation. i really appreciate all the help you have offered. hope to return the favor. have agreat weekend, Randy
                • copygirl
                  • 75
                  There are new ROM's that go on the operation panel and the controller board to correct some of the issues on the new machine. The old style has the gold lettering and the new white. Would have to look at paperwork but think that's it.
                  Ginger
