MAC OS X 10.8 SMB/FTP Scanning
  • TA_Tech
    • 76
    Hi Guys
    Can anyone help me with this. I'm having no joy setting up scanning to a shared folder on a MAC 10.8 from a Canon iRC1028.... the same copier scans fine to a Windows 7 Box. In the interim I've created a second share on the Windows 7 box and i've created a shortcut on the Mac to this folder. Also, I noticed that there is no FTP on the MAC??? is this normal? can it be activated somehow? Is there a mini FTP Servlet that can be downloaded?
    I dont Deal with Macs too often. 99.9% of my customers are Windows based. The Macs that i have, havent given me any headaches with regard to scanning. This is the first Mountain Lion Mac that I have and I've heard from other Techs that they experience the same issue. Appreciate any help or suggestions
  • bilyahn
    • Dec 2006
    • 1470
    Re: MAC OS X 10.8 SMB/FTP Scanning
    I'm still trying to get this to work properly on our shop 10.8. Have it setup perfect on our other MAC 10.6.8 but we upgraded this MAC from 10.7 (which worked just fine) to 10.8 which hasn't worked since. We have shared everything including the entire computer but it will not work! 10.8 requires a username/password combination everytime you access a shared folder no matter how you set the folder up. Called Apple and spent over an hour on the phone talking with their "tech" and he said you would need to contact you OEM provider (in our case Sharp, we are the provider by the way) for resolution! My boss is very dissappointed with them at the moment! Would like to know if you find any type of solution.
    Good luck.
    Bil
    PS I can access the shared folder from our other computers but it still requires a user name and password everytime I try to access. From both a MAC and Windows computers.
    • TA_Tech
      • 76
      Still no joy I'm afraid. I'm not so certain if my problem is the username and password, because this is saved as part of the address book entry on the MFD, along with the IP Address of the Mac and the sharename of the folder. Unfortunately I haven't had much opportunity to play with this because this customer is a good 100 miles away from me, so everytime i have something to try i do it via a teamviewer session, which makes it difficult and time consuming. BUT if i do manage to figure this out you'll be the first to know.
      • ruben
        The New Guy
        • Oct 2012
        • 1204
        Mac OSX >= 7 uses a proprietary (i.e. closed source) version of SMB developed by Apple, instead of the usual Samba / SMB that Mac OSX < 7 and Windows uses. (It removes SMB over NetBIOS for one, which a lot of equipement use, and changes the port.) You can re-enable SMB by downloading SMBUp.
        See: http://www.copytechnet.com/forums/ri...tml#post322532 and http://www.copytechnet.com/forums/ky...tml#post332905
        You may need a firmware update to scan without any modifications to Mac, if such an update is ever produced or released.
        • rthonpm
          • Aug 2007
          • 2859
          Like always, Apple has made changes to their Samba implementation. More than likely, you'll need a firmware upgrade for the machine similar to what people have needed for Windows 8.
            • 23010
            Tell me if I'm repeating this correctly:
            On 10.8 OS and up SMB2 is not available. There is a utility called SMBup that adds SMB2 to these OS. It can be tricky though. See other threads on this topic.
            Download SMBUp for Mac - Reinstate and manage Samba on OS X 10.7 Lion. MacUpdate.com
            I haven't done it myself but gleaned this much from the current threads.
            • Mr Spock
              Vulcan Inventor of Death
              • Aug 2006
              • 2064
              I will have to find a way to get screen shots.
              I have set this up on several Km boxes. I have an account that has 3 different KM machines and all scan via smb to 2 different mac 10.8 boxes. It took 3 days before I got it working then just did the same steps on both macs.
              Also there is a built in ftp in mac 10.8 but you have to drop to a command line to implement it. (I do not know how but google it and you should find it.) Also the username/password is the only login that can open the file once scanned to the macs. Will this work on canon machines I do not know.
              • bilyahn
                • Dec 2006
                • 1470
                Recent update to MAC 10.8.x now allows access to shared folder without login but still no joy on scanning to shared folder (only tried to setup for about 1/2 hour so didn't really give myself much time for troubleshooting). My boss said she will just use her iphone or her ipad which both work just fine!!!!
                Bil
                • THUK
                  • Jul 2008
                  • 195
                  Hi SMB Scanning is not supported on 10.8
                  • techsass
                    • Dec 2010
                    • 248
                    I haven't had a single 10.8 customer ask me about scanning yet, but I did a bunch on 10.7. If the firmware updates don't resolve SMB scanning, I'd use FTP.
                    On MAC 10.7 I went to Terminal (Finder/ search Terminal) and entered
                    "sudo -s launchctl load -w /System/Library/LaunchDaemons/ftp.plist" (leave out the "s) to enable FTP. I got this from the MAC support site and it worked just fine.
                    Of course 10.8 may be different, but there should be directions on how to enable FTP on the MAC site.
                    Last edited by techsass; 05-25-2013, 11:40 AM. Reason: put the "sudo..." path on 1 line
                    • habik
                      • 2013
                      10.7 and 10.8 uses the same ftp enable string in terminal however you may watch for shortest destination root so you don't expose too much of the shared folders.
                      Firmwares HERE
                      • RollingROARANDA
                        • Nov 2012
                        • 72
                        Scan to a LION - YouTube
                        I made this video to train my guys with the Kyoceras..
                        I apologize for bad quality.. And it doesn't really start until 35 seconds in.
                        PS: I always do it with a static IP or DHCP reservation; at least with these Kyoceras, it just won't resolve Mac hostnames; your result I think will vary with the make/model.
                        • ApeosMan
                          • Nov 2009
                          • 183
                          Annoyingly the only way to get SMB scanning to work on 10.7 and above is for the MFP manufactures to update their firmware to support the SMB level the newer Mac OS's use.
                          I've been using the FTP utility for FTP scanning, makes things easy, but you can only scan back to the users home drive:
                          ::: Lion FTPD Enable :::
