Import 900+ Fax Numbers to Kyocera 5500i address book from .csv
  • RollingROARANDA
    • Nov 2012
    • 72
    There's gotta be an easier way to do this. We got an excel sheet, made a csv file, and I can't find where to do this with the latest version of KM Net viewer. This makes my head hurt! It sucks! But it has to be done. Customer thinks it's a same day kinda thing but with copy and paste, we're like 200 something in.
  • andrewsbarton
    • Aug 2013
    • 5
    Re: Import 900+ Fax Numbers to Kyocera 5500i address book from .csv
    I have heard others complain about the same thing with some of the newer KM Net v.5 and newer. Try to open Km-Net-Viewer in "General View", highlight device, open top "Device menu" -> Advanced -> Set multiple Devices -> Device Address Book -> Create from File. If you don't see it there, maybe switch back to version 4 if that is an option.
      • 23006
      I struggled with this with the VoyagerE series. The problem is that the list is encrypted. Each series of machines is differently encrypted. I could create a list, but could not get past the encryption.
      The only way I know is to use the Setup Utility to manually enter a list, or enter the list once from the machine panel, then use U917 to export/import it to other machines of the same series.
      I know this isn't the answer you're looking for, but I don't have a better one. =^..^=
      • Master Sparkee
        • May 2010
        • 31
        Having a similar issue. Machine's Secure Communication Error Log History shows SSL 1046 errors. Net Viewer can wipe the current address book but will not accept a csv file (any version of .csv). TASKalpha 4004i most current firmware. Tried disabling/enabling all ssl in machine and net viewer. At a loss. If you have any suggestions I would appreciate them.
        Sorry, no. Techs don't carry toner.
          • 37458
          Start a new thread. This thread was almost 10 years old, dead and buried grave robber.
