Scan to folder using V-lans(virtual networks) Sharp MFP
  • neilobusk
    • Mar 2012
    • 16
    Hi
    any one experienced problems scanning to network folders when v-lans are involved
    scan to e-mail and a couple of pc with sharpdesk work fine
    A customer of ours recently updated to v-lans and now...intermittantly the mfp`s come up with the error selected servers not found scannig to network folders
    Is this possibly a port issue as scan to email and sharpdesk work they use different ports
    The MFP are sharp Mx-5000 latest firmware v5
    everything seemed to work before customer changed to v-lans
    customer is complaining that its the MFP`s at fault........yeah i know
    Im no I.T expert and am not really sure what v-lans are
    I guess there are no settings on the machines for this
    hope someone can shed some light on this issue
    many thanks
    neil
    in the sunny uk
  • RollingROARANDA
    • Nov 2012
    • 72
    Re: Scan to folder using V-lans(virtual networks) Sharp MFP
    Originally posted by neilobusk
    Hi
    many thanks
    neil
    in the sunny uk
    So... The Sharp is scanning to some of the desktops using Sharpdesk utility, but not others...
    Here's a question you can ask the customers IT Dept:
    Do they have Trunk links setup so that the VLANs can move traffic from one switch to the other? If so, are the PCs that are unable to scan in a different VLAN than the Sharp is assigned to?
    It seems your issue is on the customer's IT, because VLANs logically place devices on specified switchports in different networks, and without
    inter-VLAN communication, scanning won't happen. Owl, can you weigh in on this please? The Owl knows..
    • neilobusk
      • Mar 2012
      • 16
      Hey thanks for the info on this
      At the momment it seems to be a problem with the machines using hostnames in the folder paths...if we use the ip address instead things seem to work........
      Machines time out we think if they can`t resolve the hostname...
      It is not The mfp`s at fault...surprise,surprise
      As i said everything worked before the v-lans were added/fitted or whatever you do with them...
      Many thanks
      neil
      • rthonpm
        • Aug 2007
        • 2854
        It sounds like there's a latency between the VLANs and DNS. Since the machine works by IP, I'd have the customer's IT look at the responsiveness of the DNS server onsite.
        • neilobusk
          • Mar 2012
          • 16
          Thanks for that
          Thats what the customer is now looking in too
          Main thing is ..the MFP`s are not at fault
          I know updated firmware for the machines sometimes helps with the latest I.T developments but that is up to date
          neil
          • RollingROARANDA
            • Nov 2012
            • 72
            Many thanks
            neil
            Yes sir, if the machine doesn't scan to host, the next test is always scan direct to IP, especially if you're more than sure everything else isn't a cause ( i.e. incorrect path and share name , authentication, firewall). Then the customer's IT can resolve.
            • Tonerbomb
              AutoMajical Resolutionist
              • Feb 2005
              • 2589
              Many thanks
              neil
              Ding Ding Ding we have a winner !!!! The customers IT dept needs to get off their asses and fix the DNS issue, and you can Bill For time and Travel !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
              Mystic Crystal Revelations
              • RollingROARANDA
                • Nov 2012
                • 72
                And the bills pay the bills haha
