Failure to auto-grab an IP address using DHCP network setting in a printer
    • 23008
    #16
    Re: Failure to auto-grab an IP address using DHCP network setting in a printer
    Originally posted by Ceechtay
    ... I know you have tested with a laptop, but I have seen one location where a Sharp copier couldn't get on the network, while a laptop could, when using the same network jack. I'm guessing that the laptop NIC has more fault tolerance or some OS feature that corrected any problems. ...
    I came across this same thing on an MX-5111N. The laptop connected fine, but the Sharp copier would not. After wasting a good hour trying to connect on jack #1, I eventually tried jack #2 and it worked. The cheap and easy answer was to place a 5-port network switch and split jack #2.
    A network drop may very well have solved the problem, but I didn't really see any point in diagnosing it any further. =^..^=
    • Iowatech
      Not a service manager
      • 3930
      #17
      Is the correct software package installed on the correct computers correctly? I don't know about Fuji Xerox, but I know that's how HP makes this work.
      Rats. I would like to personally apologize for using the word "correct" that many times in one sentence. Still, if you can, see if the software is on the computers, it might not be a machine or a network fault.
