Kyocera 3035 , scan to mail setting
  • pinspin
    • Oct 2011
    • 156
    Hello .I can not change the limit on the size of the letter (I change the data in the = send E-Mail setting =, but the copier does not remember changes . Same thing happens when I select non restrict setting . This occurs on multiple copiers, replacing a scanner card does not help. SFU operating normally. Can you help, please?
    • 23009
    Re: Kyocera 3035 , scan to mail setting
    Try a different browser. =^..^=
    • pinspin
      • Oct 2011
      • 156
      Thanks, I'll try
      • pinspin
        • Oct 2011
        • 156
        thanks, but it did not help (((
          • 23009
          The next thing I'd do is re-load/upgrade the scan card firmware. It requires the utility: IBVERUP and the firmware.
          Before you ask, I don't provide firmware. But maybe Paul can help you at www.justmanuals.com
          • pinspin
            • Oct 2011
            • 156
            Thank you, my friend )))
