Bizhub c284 wont print without restarting machine
  • patk
    • Jun 2008
    • 56
    We have a strange network issue.
    Customer has bizhub c284 and complains that when printing, nothing comes out of the machine until they switch machine on and off. Customers IT support has monitored machine and says that machine regularly becomes unresponsive and web interface goes down.
    The machine has worked perfectly on the customers network until a few weeks ago and the customers IT support say that nothing has changed. We have replaced HDD, memory DIMMs and switched off SNMP on TCP/IP Port monitor.
    We removed the machine and set it on our network and it performs perfectly. No printing issues, no hangups and we have also monitored the web-interface which has 100% uptime. This over a period of 10 days. we return the machine and it has the same problems again almost immediately.
    So it sounds like a network problem- except that a bizhub c280 setup in place of the c284 has had no issues on the customers network.
    Would be grateful for any ideas on what this could be.
    Cheers
    Pat
  • patk
    • Jun 2008
    • 56
    Re: Bizhub c284 wont print without restarting machine
    Yes did that
    Cheers
    Pat
    • emujo
      • Jun 2009
      • 3009
      Try updating firmware to A9. There was a problem with SSDP that was giving symptoms like this. You can try just disabling the service via the web interface just to see if it makes a difference. Also, you may get more responses if you re-post your question in the KM forum. Emujo
      • dickierock
        • 252
        Get their IT people to check the firewall settings on their network.Had something that sounds very similar with a c203. The machine would print initally then go dead on the network.It printed fine using a laptop and crossover cable.It turned out to be their firewall causing the issues.
        • qbert69
          • Mar 2013
          • 1152
          "Link Flapping" on the Switch/Router port???
          REACH FOR THE STARS!!!
          Konica Minolta Planetariums!
            • 37484
            Try connecting another printer on the same network cable. If the other printer does the same thing, they need to replace the network switch. I had this same problem with a Ricoh a couple of months ago.
              • 23007
              This is really common with Konica Minolta GigaBit/second capable printers, when installed on a 100MBs network. The fix is to change from Auto Connection Speed to a manually selected 100MBs. =^..^=
              • TheOwl
                • Nov 2008
                • 1732
                This is exactly what I would be doing.
                • JustManuals
                  • Jan 2006
                  • 9838
                  paul@justmanuals.com
                  • supertype
                    • Sep 2012
                    • 31
                    has anyone checked for another machine or device that's capturing the copiers IP address?
                    Ping the IP address of the copier and unplug its network connection, wait for a bit and see if it starts pinging again.
                    try setting it up above the DHCP range if its not already.
                    • Doclogic
                      Cheers
                      Pat
                      Hi Pat did you come right here and if so how, we have the same problem?
                      • patk
                        • Jun 2008
                        • 56
                        Hi
                        Yes- machine is back at customers 10 days no problems.
                        We switched machine from Auto 10/100/1000 to Auto 10/100. (The bizhub C280 that we loaned them only auto negotiates at 10/100 even though it has Gigabit ability)
                        we suspect that the problem is with the Cisco network switch, maybe an auto update on it- See my full update in the Konica Minolta forum
                        Cheers
                        Pat
                          • 23007
                          Congratulations. =^..^=
                          • douglasdouglasv
                            • Dec 2012
                            • 20
                            novell
                            If they use novell the machine and novell server must be within 5 minutes on their clocks or it won't print.
