Has anybody had a problem finding an installed printer in the windows 8 devices and printers listing.
In my case, I have a bizhub c35 which is connected to a single windows 8 PC. The printer can be found in the list of available printers from the print menu in any application.
I need to set it as the default printer and specify some default settings but it is not listed on under devices and printers through the control panel.
I googled it and found it to be a common occurrence, but no fixes were reported. One guy said it showed up an hour later.
Has anybody seen this and have a suggestion to correct it?
