Scan to e-mail via Windows Live Hotmail
  • ApeosMan
    • Nov 2009
    • 183
    Hi,
    Has anybody successfully scanned to e-mail via Windows Live Hotmail? I've never needed to set it up surprisingly, though I've setup Gmail dozens of times. I don't have a need at the moment to setup scan to e-mail via Windows Live Hotmail, but I'd like to know if it's possible and works well. Unfortunately I can't test this on my test machine in my office as the corporate firewall blocks the connection.
    I've found a web page that goes through the settings: http://email.about.com/od/accessingh...P_Settings.htm
    The guide mentions to use port 587 though like most guides it fails to mention that you'll need to enable 'STARTTLS' instead of 'SSL/TLS' as STARTTLS uses port 587 and 'SSL/TLS' uses port 465. I suppose if your MFP doesn't have a 'STARTTLS' option you could always just try 'SSL/TLS' and see what happens.
    Thanks!
  • peterxu256
    • Jul 2014
    • 110
    Re: Scan to e-mail via Windows Live Hotmail
    Failed to install hotmail SMTP server, since it requires
    • Encrypted Connection: SSL
      Ricoh machine says it needs installing Device Certificate if SSL (SSL/TLS is unavailable without device certificate installation.)
      Therefore create certificate1
      : Creates a self-signed certificate. have you any idea to solve the error
      but say:
      Error
      An unexpected error has occurred.
    • ApeosMan
      • Nov 2009
      • 183
        but say:
        Error
      Ah I'm a bit confused by that error message. When an SSL/TLS session is being established the mail server should send the certificate for the secured connection, you shouldn't need to upload it to the MFP manually.
      • peterxu256
        • Jul 2014
        • 110
        Probably you don't catch the point. I mean the failure message from installing Device Certificate. I tested many times by using different web browsers, IE,Firefox,Chorme, they came the same error message, However I created the Device Certificate easily for a little bit newer model like MP3500 or MP4000, 5000. But it really doesn't work for the Model MP2500. I'm wondering aloud the model has the function from webMinitor to create self-signed device cerificate, why it doesn't work, Is it a kind of bug? or I omit something ??! Furthermore I also can import the third party certificate(like Equalfax Authority) to Site certificate I get a little puzzle from Ricoh MP2500.
        In general, Ricoh Network Configuration description is much ambiguous, unclear, or non professional narration, like Wireless and IPfax setting. Without Cisco CCNA background, no one can figure out setting properly. Fortunately I have had the background knowledge- Networking Infrastructure.
          • 37201
          In order to setup SMTP over SSL on Ricoh MFP's requires the MFP to be a model that has a GW+ Controller. The MP 2500 does not. The MP 2501 does. The attached includes a list of supported models.
          • peterxu256
            • Jul 2014
            • 110
            Thanks indeed. But I am still focusing on theDEVICE Cerificate , not SSL a GW+ controller itself. The attached one says the model is much more new model(last digital starting 1, 2, or 3) , of course they offer more detailed descriptions, like SSL version.As said previous the less new model like MP3500, 4000, 5000 etc(last digital with 0) can be easily created device certificate. And also the attachment said that imported SITE Certificate, my old model can do either. Question is MP 2500 only recognize the Device certificate.
              • 37201
              SITE Certificate is used for SMTP over SSL which the MP 2500 cannot do because it has a GW Controller and not a GW+ Controller. Device certificate is used mostly for authentication with other services usually from local servers and is obtained from a local domain certificate server. There are also self created certificate functions available with some model, but I have not used one before. Self created certificates must then be registered with any server requiring a certificate.
              • peterxu256
                • Jul 2014
                • 110
                More clear than before, meanwhile, allow me to ask what is different between GW Controller and GW+ controller, further humble ask for what stands for GW , Thanks
                  • 37201
                  I do not know what GW stands for. Possibly the company who manufactures the boards for Ricoh. It is a term used by Ricoh for some of their boards. GW controller is the main controller board. GWFCU is the FAX control unit. The GW+ is an updated version of the controller. It has a newer processor chip and support chip set. As such, it supports additional and updated options and features.
                  • peterxu256
                    • Jul 2014
                    • 110
                    Thank you for your sincere answers, As a matter of fact, Ricoh use too much abbreviations, even for not common use. We have to spend a lot of time to memorize the Abbreviations or SP/SC number, we have to write down notes for future reference.
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      "GW" stands for "Grand Works".
                      How's that for trivia?
                      • peterxu256
                        • Jul 2014
                        • 110
                        Probably it is, honestly I only saw once a time somewhere, after that explanation never appear, i.e. Like "MUSIC" Mirror Unit For Skew and Interval Correction), Never repeated Twice. Also like memory clear (sp5801), sub section's abbreviation, I wrote on my note, lazy to remember, one day the note was left on site, On next site, it made me embarrassing...
                        • qbert69
                          • Mar 2013
                          • 1152
                          What's really stupid about this whole deal, is that Ricoh has not enabled self signed SSL security certificates on their machines. This is really quite lazy on their part.
                          How would they implement it?
                          Using the MAC ID of each NIC Card and the Serial Number of the machine itself.
                          Based on these two unique items, the machine should be able to create a UNIQUE
                          certificate, since the MAC ID never changes and the machine serial never changes!
                          Both of these items are on file with Ricoh.
                          REACH FOR THE STARS!!!
                          Konica Minolta Planetariums!
                          • ApeosMan
                            • Nov 2009
                            • 183
                            If you want to know how to import a device certificate into a Ricoh device, then create a new thread and don't go off topic on this one. This thread is about setting up scan to e-mail via Windows Live Hotmail.
                            I'd appreciate if a moderator could delete the off topic posts. Thank you.
                            • peterxu256
                              • Jul 2014
                              • 110
                              The device certificate is highly associated with the topic, SSL , windows live hotmail's STMP sever must use.
                              Why do you so aggressive? do you know the Charter of Free of Speech? I don't mind if you are police of the website, but I am proud of saying PUBLICLY , My IT knowledge is much better than yours. I got the Cisco CCNA certificate 13 years ago although I am involved in the copy business for just 3 years. Please, please kindly respect each other virtually.
