Has anybody successfully scanned to e-mail via Windows Live Hotmail? I've never needed to set it up surprisingly, though I've setup Gmail dozens of times. I don't have a need at the moment to setup scan to e-mail via Windows Live Hotmail, but I'd like to know if it's possible and works well. Unfortunately I can't test this on my test machine in my office as the corporate firewall blocks the connection.
I've found a web page that goes through the settings: http://email.about.com/od/accessingh...P_Settings.htm
The guide mentions to use port 587 though like most guides it fails to mention that you'll need to enable 'STARTTLS' instead of 'SSL/TLS' as STARTTLS uses port 587 and 'SSL/TLS' uses port 465. I suppose if your MFP doesn't have a 'STARTTLS' option you could always just try 'SSL/TLS' and see what happens.
Thanks!
Thanks!
