How to MFP Sync with Active Directory
  • dumdupdip
    • Jul 2025
    Dear Everyone,
    Please advise me about connectiviry between MFP with AD , How to MFP syn information with domain (How often, How to ).
    Cause have some problems related printing data msg (withing for print data).
    Thank you.
  • rthonpm
    • Aug 2007
    • 2854
    Re: How to MFP Sync with Active Directory
    Model of the MFP(s)? AD type (2003, 2008, 2012)? More information needed.
    • emujo
      • Jun 2009
      • 3009
      At least with the KM products (and I don't include any 3rd party software) the MFP doesn't "sync" on a time basis. If you have the correct info entered AD type, address and search base, then the MFP just looks at your credentials when you log in. If you are an active member of the domain with proper credentials, you are logged on. As far as printing, nothing entered into the MFP will affect if you can print, that is done on the AD side, meaning who has right to that printer. So if something is being deleted or missing I would not look into AD for the fix. Emujo
      • TheOwl
        • Nov 2008
        • 1732
        We need more information on your issue.
        Emujo is smack on the money in regards to the "sync". No machine caches a copy of AD as AD will not let up this information unless your copier somehow becomes an authorised Domain Controller.
        When talking to AD or LDAP (Active Directory is actually both), the machine simpy makes a query to the directory and a response is only giving if the devices correctly authenticates. Instead of syncing information, the machines are requesting for the information each time as an update in AD could happen 30 times a day, if not more in a large network.
        Tell us exactly what you are trying to achieve and what you have tried so far and we may be able to help. Don't forget to include what sort of machine you are working on.
