i bought a copier that was use in a government location It had the Doc Server button on it but when i push on it nothing happens. I notice on scanner that it load java software and has a vm sd card when i remove it it acts like a regular scanner setup. How do i get doc sever working is it a software that i have to load back on or is it a chip that has to be added to board.
Ricoh Mp 2550b copier
Re: Ricoh Mp 2550b copier
Hey copierman because its solely a basic model MFP, it's specifically a copier only machine however you can add other functionality options into the machine. To get the document server function it requires a hard drive option in the machine. With the java option its best to allocate that option into the 'other functions' button on the op panel.Comment
MORE THAN LIKELY...
...if it was a "guvmint" machine, they pulled the hard drive for data destruction!
It will have "basic" functions without the hard drive but when it comes to the doc server, you MUST have a hard drive! Hopefully the just took out the hard drive and left the drive carrier and all connectors!
CHEERS!REACH FOR THE STARS!!!
Konica Minolta Planetariums!
https://www.konicaminolta.com/planet...gma/index.htmlComment
Hi everybody,
thanks for your help i found it finally from suggestion that were made. it was a security issue in menu protect on copier/doc tab . i had to change from level 2 to 1. in order to do this i had to turn on administrator mode first so i could log in then was able to change level. again i appreciate everyone's help.
