Ricoh Mp 2550b copier
  • COPIERMAN
    • Jun 2009
    • 559
    i bought a copier that was use in a government location It had the Doc Server button on it but when i push on it nothing happens. I notice on scanner that it load java software and has a vm sd card when i remove it it acts like a regular scanner setup. How do i get doc sever working is it a software that i have to load back on or is it a chip that has to be added to board.
    • 37521
    Re: Ricoh Mp 2550b copier
    The B at the end of the model number indicates that it is just a basic copier only. No fax. No print. No scan. They can be added though.
    • MatthewS
      • Nov 2012
      • 36
      Hey copierman because its solely a basic model MFP, it's specifically a copier only machine however you can add other functionality options into the machine. To get the document server function it requires a hard drive option in the machine. With the java option its best to allocate that option into the 'other functions' button on the op panel.
      • qbert69
        • Mar 2013
        • 1152
        MORE THAN LIKELY...
        ...if it was a "guvmint" machine, they pulled the hard drive for data destruction!
        It will have "basic" functions without the hard drive but when it comes to the doc server, you MUST have a hard drive! Hopefully the just took out the hard drive and left the drive carrier and all connectors!
        CHEERS!
        REACH FOR THE STARS!!!
        Konica Minolta Planetariums!
        • COPIERMAN
          • Jun 2009
          • 559
          Hi everybody,
          thanks for your help i found it finally from suggestion that were made. it was a security issue in menu protect on copier/doc tab . i had to change from level 2 to 1. in order to do this i had to turn on administrator mode first so i could log in then was able to change level. again i appreciate everyone's help .
