Two networks
  • JVC
    • Jun 2011
    • 151
    Two networks
    Hello
    My boss sold a machine telling the customer that the Toshiba es4520c could be hooked up to multiple networks. The customer took this as they can be set up at the same time. As usual the service department needs to fulfill sales promises. Does anyone know if this is possible or not.
    Thank you
    Joe
  • emujo
    • Jun 2009
    • 3009
    Re: Two networks
    The MFP only has one network card in it, so it can only be linked to one network...In order for 2 separate networks to utilize the MFP, the networks must be "bridged" together. Emujo
    • JVC
      • Jun 2011
      • 151
      Re: Two networks
      Thank you for the quick reply. I was pretty sure of the answer but wanted to check.
        • 23008
        Re: Two networks
        I'm not contradicting Emujo, but you can use the USB print port in conjunction with a USB to TCP/IP print server to achieve this end. Back when most printers had parallel ports we did the same thing with a parallel to TCP/IP print server, plus the built in TCP/IP port. Many manufacturers also sell optional TCP/IP interfaces, in particular Kyocera. So with a few hundred dollars you can connect to two or possibly even three networks, depending on how crazy you want to get. And it does not usually require intervention by the customers IT. =^..^=
        • avecosat
          • Jun 2012
          • 305
          Re: Two networks
          The new KM e series have the possibility conect two networks cards .
          • emujo
            • Jun 2009
            • 3009
            Re: Two networks
            Technically, true, but the 2nd network selections are for wireless access for mobile devices, and as of now the wireless cards are only available in the US for the new C3850 series, besides, he's asking about a Toshiba. Emujo
              • 37513
              Re: Two networks
              That is what I was thinking. I have seen a few inkjet printers with BlueTooth interfaces that could be connected to a network directly, a second network using a network print server as cat said, and a third network through a shared printer on a computer near enough to the printer to use the BlueTooth connection
              • Tonerbomb
                AutoMajical Resolutionist
                • Feb 2005
                • 2589
                Re: Two networks
                a few years ago I did something similar with a Savin color box. I slaved the USB print connection as a shared printer of a workstation on network 2, and set the machine on network 1 via the the network interface on tcpip............
                Mystic Crystal Revelations
                  • 23008
                  Re: Two networks
                  What Okidata used to do is link a C9600 printer to a commercially available scanner, and called it an MFP. The scanner fed the parallel print port, and the TCP/IP port was for printing. Same deal. =^..^=
                  • Mr Spock
                    Vulcan Inventor of Death
                    • Aug 2006
                    • 2064
                    Re: Two networks
                    I know of a sales MANAGER that just told me all the KM machines have had a wireless network adapter available, with the exception of the new 35XX machines, since 2006.
                    I disagreed with him but he was positively sure on this so I asked him to show me the part number. He said he was too busy to do this.
                    • bdcrandall13
                      • Sep 2010
                      • 236
                      Re: Two networks
                      You could make just about anything wireless with one of these! We use them all the time!
                      TEW-640MB_d04_2.jpghttp://www.trendnet.com/products/proddetail.asp?prod=270_TEW-640MB
                      • wseyller
                        • Sep 2012
                        • 1129
                        [ATTACH=CONFIG]24978[/ATTACH]http://www.trendnet.com/products/proddetail.asp?prod=270_TEW-640MB
                        Yeah I've had a few customers use a bridge. Some of them don't work reliably. I have charge some of the customers a few hourly network charges when it would have been cheaper and less error prone to just pay to put a network drop to the copier. Some people's mentalities I just don't understand. All I can say is don't put important devices on wireless. Wired is better period.
                        Sent from my DROID BIONIC using Tapatalk
                        • emujo
                          • Jun 2009
                          • 3009
                          Re: Two networks
                          There are wireless network settings (network 2) that you can see in service mode, but the actual wireless cards are only available in the UK. There is a wireless LAN adaptor kit/part# available from KM (SX-something-LAN) but this is only a Silas wireless access point that the MFP must be cabled directly to, and then you set up the Silex to access the customers wireless network. The MFP is not truly wireless. Emujo
                            • 37513
                            Re: Two networks
                            If they were like the Ricohs from the same era, they use WEP instead of WPA which leave the network with very weak wireless security.
