Scan to SMB impossible with XP computers
  • Techos
    • Jun 2025
    Good morning
    One of my customer recently installed a new network (server with " Windows server 2003") and computers with XP pro.It's impossible
    to use the scan to folder option , but it's possible with my own
    portable computer,also running under XP pro !
    Any help would be very appreciated
  • xcopytech
    • Aug 2006
    • 1792
    Do you send files to server (win 2003) or directly to PC`s (XP).
    On Win 2003 you have to disable SMB digital communication policy in Registry.
    Also configure firewall to allow files from machine IP address
    • Techos
      • Jun 2025
      I installed SMB scan folder on PC's only, not on the server, your right
      for the firewal ( Mc Affe antivir program), i disabled it and after what i had
      a message on the MFP ( MPC 2000) about login ID error, i can't understand why, i use an admin account whith password.
      • xcopytech
        • Aug 2006
        • 1792
        have you shared scan folder on network with premission "to allow network users to cahnge folder"
        • Techos
          • Jun 2025
          Yes i have. I'm able to ping the PC, using its name ( they have the
          DHCP option enabled), and that's all !I think the problem is that same
          old problem with XP : authentication
          • rthonpm
            • Aug 2007
            • 2848
            Try getting a user name and password for the MFP(s) created on the server so that they are recognised as valid users. The password retention can be set to never expire.
            Also, along the lines of packet signing mentioned earlier, some models require special firmware to scan to SMB on server 2003. I know for a fact a lot of older (2232c, LD145, that range) devices needed a little tweak to the firmware to get them going again.
            • GasCityKid
              • Jun 2008
              • 10
              You also may need the domain along with the username. (DOMAIN\username) as the login.
              • Techos
                • Jun 2025
                Thank your for your help !
                i will try to fix this problem as soon as possible, same old problem with
                new installation: they never make a test for all devices connected to the
                network .
                • schooltech
                  School District Tech
                  • Jun 2008
                  • 504
                  Since you're scanning to each computer, you will need to authenticate with a username/pw that does not expire (I used to set a separate one in each computer I scanned to.)
                  Also, use the computer's hostname\share in the path, rather than the computer's ip addy (for DHCP reasons.) If you don't, and use the addy, it could-but probably won't-change on you as the lease gets closer to expiring, I believe @ 50% and then at 80% of time.
                  If you decide to scan to the server, which would be better, you may need to go into the gpedit.msc and modify the smb settings (it's been a while since I've done this.)
                  Yes, as the previous post stated, you may need to use the domain\share. It's weird because some need this, and others don't.
                  There is enough people on this forum to help you troubleshoot this, so you will get this.
                  Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
