Can't print to ANY Printer
  • sandmanmac
    • 3979
    Normally, I’m resolving printing issues like this for clients, but it’s typically a printer issue. Today, it’s my own Home office problem which seems to be specifically a computer issue, and I can’t figure it out:
    I have 2 network printers that are acting the same way, but for the purposes of this, my description refers specifically to the Ricoh MP201, but both behave in exactly the same manner.
    Printing is not possible from any application from my Windows 8 Laptop, but I can print from my Windows 7 machine, and my Android.
    I’ve tried connecting directly to the printer via Crossover, to exclude a router issue. I’ve tried disabling my Internet security program in case it was a firewall conflict. I’ve restarted the PC and print spooler several times. The printer (s) appear as “Online”, and I can Ping it.
    I don’t have a USB cable on hand right now, so I can’t say if that works or not.
    I can scan to email and/or folder.
    When I send a job the data light flashes briefly, then stops –almost as if authentication (or user codes) have been enabled.
    If I try sending a printer Test page, the data light flashes constantly and never stops, and the printer must be restarted to clear it.
    I thought maybe a windows update may have screwed something up, but there haven't been any installed in about 10 days.
    Did quite a few internet searches, but have come up empty so far.
    I'm at a loss
    Any thoughts about what might be causing this?
    Thanks!
  • 88hawkfan
    • Jun 2014
    • 76
    Re: Can't print to ANY Printer
    Have you checked SNMP?
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      Try printing something very simple, like a one line text file, but point to file, and post it here.
      That way we can analyze it to see if it's something in the way the data stream is being created.
      • sandmanmac
        • 3979
        No. I have not. I'm mostly an MFP connectivity guy (more specifically, Ricoh), so much of the I.T stuff relating to the PC end of things is not exactly my strong suit.
        Is there a quick and easy instruction you can give me to get me started? Do I use a specific program?
        You guys are really exposing my shortcomings today
        I just tried printing from "notepad" and that worked.
        Not sure what you mean by "point to file", Ken
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          Sorry, fat fingers. I meant "print to file". Duh.
          In any case, seeing how notepad seems to be OK, please try a file which bombs: Word, PDF, etc...
          • rthonpm
            • Aug 2007
            • 2848
            Are you using the drivers from Ricoh on the Windows 8 machine, or did they get sucked in from Windows Update?
            Have you checked to make sure all of the driver settings are correct? Happy fingers maybe turned a setting on in the driver by mistake?
            Try a repair install of Office through Add/Remove programs and a repair of Acrobat from its Help menu. You'll need a reboot after each, and I've seen them hose the print function.
            Have you tried changing the printer port to LPR, queue name lp? Ricoh always recommended LPR as the preferred printing method.
            • sandmanmac
              • 3979
              I should have been able to put that together.
              Just had to research how to install "Print to file", since it's not a standard option in the dialog box anymore. I've always seen it in the "ports" box but never knew what it was for. (I'm learning already!)
              Just FYI, and it may mean nothing....I was originally going to upload a document that simply read "test", but it will print any document with up to 4 letters - NO PROBLEM. I tried almost every 4 LETTER word l know!
              The minute I add a 5th letter, it gives me the middle finger. (Although Notepad still works)
              I tried to upload the PRM file, but it is not a 'valid" type.
              Here's a link to download it from my dropbox.
              Thank you!
              • sandmanmac
                • 3979
                Thanks, but Yes, I always use the ricoh factory drivers, the other printer is an OKI, and I'm the only "happy fingers" in the place.
                Also, No, I haven't tried a reinstall of my PDF reader (foxit reader) or MS office. Maybe that's next
                Edit: Tried uninstalling Foxit reader, and tried the stock Viewer in Win 8 afterwards. No luck yet. MS Office may be a chore for another day.... if it comes to that
                  • 22997
                  You can open and read your .prn file in Notepad, Textpad, and XVI32 text editors. Notepad is the weakest of these options because you can't do anything with the null characters. Personally I prefer Textpad for it's simplicity.
                  Are you using WSD driver? I've had various problems with the WSD drivers, and generally select PCL6 or PS3. =^..^=
                  • KenB
                    Geek Extraordinaire
                    • Dec 2007
                    • 3944
                    There at least appears some issue in the file.
                    PageTech PCL Reader throws an error when I try to open (view) it, yet works correctly with a file I created with the Universal PCL6 driver.
                    I will try downloading the test file you provided to a few machines in my office on Monday.
                    BTW... Notepad++ is a good editor to look at the code in print files, although it can't wrangle non ASCII characters very well, as Blackcat mentioned.
                    It's a free download, and smokes Notepad.
                    • allan
                      RTFM!!
                      • 5462
                      I found a lot of problems if Win8 upgrades to Win8.1 with existing printers installed.
                      Whatever
                      • sandmanmac
                        • 3979
                        Thanks, Blackcat, but my issue isn't with opening the .prn file, it's having NO IDEA what any of the info means in the first place.
                        That type of stuff is not in my wheelhouse.
                        I just created it on the advice of KenB to see if there were any obvious errors that were preventing me from printing anything from any of my printers.
                        I'm using the PCL6 driver.
                        I just tried the PS drive on the Ricoh and it prints "some" of the page of a document, and then continuously shoots out pages with a little bit of an error message in the top corner of each
                        Thanks Ken. I looked at the .prn file, but it might as well be in Swahili for what any of the text in there means to me
                        I appreciate you taking the time to help.
                        I've had Win 8.1 for about a year now (give or take). Never had a problem...
                        Although, ironically, I have a client who upgraded to Win 8.1 several months back, and was experiencing the same problem, and has had printing issues ever since.
                        The 2 other people in the office have no issues, but he needs to connect via a USB cable to print.
                        He also has the exact same problem when trying to print on his home network.
                        No DICE!
                        So it seems there must be some issue with the OS or maybe a conflict in some combinations of programs , but I haven't been able to find out anything at all.
                          • 22997
                          Another way that you can test the ability to print is to use LPR Jar to send a data capture (or print-to-file) directly to the printer's IP address. If you are having a problem with port 9100 (that print drivers use) LPR Jar will be able to send anyway. =^..^=
                          • sandmanmac
                            • 3979
                            Unbelievable!!
                            Thanks so much!
                            Also to rthonpm who suggested LPR very early on in the thread, and I didn't pay much attention.
                            Remarkable, that I've heard LPR suggested to others many times in the past, and never, ever, have had the need to even try it as a fix for a printing issue myself.
                            I simply set both printers to "LPR" with queue name "Ip", and BINGO!
                            Still strange to me why both my printers would just go down out of the blue, for no apparent reason.
                            Admittedly I don't truly comprehend the protocols of how this end of things works, many thanks to all of you experts for sharing your expertise!
                            REP points earned!
                            • emujo
                              • Jun 2009
                              • 3009
                              Windows 8 has a new port ( can't remember the exact name WSD or something to that effect), but look at the port settings in the driver and ensure you are attached to a standard TCP/IP port. Also if you let Windows choose the driver it might add the XPS version which IMHO is just about useless. Additionally, on some MFPs Post Script drivers need additional hardware installed in MFP. PCL would be my 1st choice..Emujo
