Scanning to Shared folder on Windows 7 pc
  • Dreama
    • Jan 2013
    • 43
    hi,
    customer of ours has had issues with scanning to a folder that their IT person has setup.
    I have got it to the point where the Ricoh mpc3001 scans ok - for a while, then later on it stops. Reboot the PC and it works ok again.
    i have tried to pass this back to their IT but i think due to his lack of knowledge or something he doesnt think its a PC issue.
    I have tried the power settings of the network card (Local Area Connection Properties, Configure, Power Management and Untick the Allow the computer to turn of this device...)
    Anything else that I can try?
    • 23007
    Re: Scanning to Shared folder on Windows 7 pc
    Exactly what kind of scanning are you doing? SMB, FTP, ... probably not Email or TWAIN. =^..^=
    • epintotox
      the noob one
      • Mar 2015
      • 14
      Originally posted by Dreama
      hi,
      firewall setting ?
      • Dreama
        • Jan 2013
        • 43
        Sorry - using SMB
        • Dreama
          • Jan 2013
          • 43
          would the firewall not block SMB and then start blocking though?
          Originally when scanning wasn't working at all, turning the firewall off made no difference.
          What got it working was turning Password Protection ON under the Advanced Sharing Settings, and then rebooting the PC.
          • habik
            • 2013
            Is the customer on wi-fi? If so make sure the network he connects to is set as home/work. Occasional switch to public will disable firewall incoming traffic. Option 2 would be to put the scans folder to public folders and just make a shortcut to scans placed in Desktop.
            Sent from my iDon't believe in marketing device using Tapatalk
            Firmwares HERE
            • rthonpm
              • Aug 2007
              • 2853
              Static IP or DHCP for the computer?
              • qbert69
                • Mar 2013
                • 1152
                In the folder sharing under the Security tab, down at the bottom is an "Advanced" button. Open and there is a Auditing tab. Under Auditing, add the MFP user that is logging in to scan files to that folder. I have seen that not setting this function can either make or break this functionality!
                Also, If they are using any kind of security software, ESPECIALLY AVG! (I DESPISE AVG!), make sure to add an exception for that folder so it is not being blocked by the security software!
                Also, see if you can browse the network from the MFP and "drill down" to that computer and the scan folder located on it!
                GOOD LUCK!
                REACH FOR THE STARS!!!
                Konica Minolta Planetariums!
