HP Officejet Enterprise Color X585 Error 610000 and 610002 with C6FD0002 sub code
  • Bill Fla
    • Apr 2011
    • 12
    We changed the formatter board and it gave the same code, you can hide it and still go into diagnostics but it won't print anything. Any ideas
    • 22808
    Re: HP Officejet Enterprise Color X585 Error 610000 and 610002 with C6FD0002 sub code
    • Bill Fla
      • Apr 2011
      • 12
      Thanks, I already have the manuals, they are not that helpful
      • Lance15
        • Jun 2015
        • 1069
        These models (X555/X585) use the familiar xx.xx.xx error codes from what I'm seeing. Are the codes your seeing not in this format? I'm not seeing anything in that format even on the Channel Services Network.
        • Lance15
          • Jun 2015
          • 1069
          Not saying this will help any, but, are you able to load the latest firmware? I noticed this model accepts the FutureSmart 4 Firmware.
          • Bill Fla
            • Apr 2011
            • 12
            I did load FS3 firmware, I did not try FS4 firmware, also the C6FD0002 says General engine failure after it says the connection between the formatter and engine is lost. Do you think the FS4 firmware might fix that?
            • Bill Fla
              • Apr 2011
              • 12
              yes 61.00.00 and 61.00.02
              • Lance15
                • Jun 2015
                • 1069
                From the latest CPMD:
                C6XXXXXX
                C8XXXXXX
                Printbar malfunction. Replace engine with mech kit.
                X555_X585 - Print Bar.pdf
                  • 22808
                  C6XXXXXX
                  C8XXXXXX
                  [ATTACH]40288[/ATTACH]
                  wow from the list of serial/models affected... seems like the whole LINE!
                  and that printbar could be a PIA job!
                  • Lance15
                    • Jun 2015
                    • 1069
                    Yep. Similar to the old X45x and X47x series. HP kept updating the service advisory and it ended up with them just replacing the whole printer because of the difficulty of replacing the printbars.
