it 2525 firmware
  • totongkol
    • Jun 2019
    • 2
    [CQ] it 2525 firmware
    How to get ir2525 firmware.i replaced the system board as the old one was damaged
    regards
    Sent from my SM-G975F using Tapatalk
    • 22808
    Re: it 2525 firmware
    Originally posted by totongkol
    How to get ir2525 firmware.i replaced the system board as the old one was damaged regards Sent from my SM-G975F using Tapatalk
    from the Tech support website?
    what 'damage' did the board suffer?
    do you really have a CQ issue?
    • totongkol
      • Jun 2019
      • 2
      Thanks for the reply,the lan cable port was damaged.
        • 22808
        if it is a thru hole connection you can find the port online and replace that. better/cheaper than board replacement
        you should have tried to back up HHD files also
