Hi folks, i have an ir3300 not detecting paper in all the cassettes, however the by-pass is working. sensors seem to be ok, any suggestions to possible solutions welcome. thanks in advance.
Canon ir3300 doesnot detect A4, A4R,A3 cassettes
Tags: None
Re: Canon ir3300 doesnot detect A4, A4R,A3 cassettes
I had this problem before in Canon irc2220 i take out the pick up assembly cleaned the load paper switch and the machine working fine. -
-What sizes do they detect
-When does this detection issue appear ?? loading paper ? or a message appears to load correct size for printing/copying ?
-Is this a Jamming>size issue ?
-Did this happen out of the blue> or after service ?
Perform the adjustment of the Paper Width Basic Value in Service Mode > Function CST ?
DCON clear_? make sure to print out a P PRINT before this clear & re-input those settings.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Does it attempt to lift, making it's lovely "clackety clack" noise? If it makes the noise, but only lift 1mm up, down, up, down, then you've got missing teeth from the lift ratchet. Sometimes changing the amount of paper will get it working, until you get to that worn part of the ratchet.
It's a really fun job. I think I've already posted the disassembly procedure somewhere. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
