IR 5075 LASER ACTIVATING
  • zelotprotos
    • Apr 2014
    • 36
    [Electrical] IR 5075 LASER ACTIVATING
    The Laser Shutter is activated by the pin on the Primary Fan Duct Assembly.
    What will happen if I just activate the laser by making a permanent activating that I push the knob(button) on the laser with a trick or glue.
    Here I show you a picture of it.
    Thanks for the advice
    • 23010
    Re: IR 5075 LASER ACTIVATING
    The world will disappear into a time swallowing vortex, then drop through a black hole ... just kidding.
    The chances of you getting your eye lined up with the laser beam and suffering crippling vision loss are slim-to-none. When I have encountered laser shutter issues that is the first thing that I would do. You'll just have to exercise a certain amount of caution where exactly you were cramming your cabeza, when you have all the imaging components out, and all the doors open, and all the doors interlocked, assuming that the machine did not code out immediately. =^..^=
    • zelotprotos
      • Apr 2014
      • 36
      Thank you Sir.
      Will it cause a damage to the laser itself or to the other component?
        • 23010
        No sir. =^..^=
