Photo copy from F4 size paper to same F4 size paper in canon imagerunner
  • gorganite
    • Apr 2015
    • 14
    [Misc] Photo copy from F4 size paper to same F4 size paper in canon imagerunner
    dear all,
    how we can make Photo copy from F4 size paper to same F4 size paper in canon imagerunner 4580IRC as far as print is concern we have tried with stack by pass and sending it as letter or a4 and choose stack bypass for printing.
    but for copying it not happening
    thanks
    • 16083
    Re: Photo copy from F4 size paper to same F4 size paper in canon imagerunner
    Can a non-standard paper size be set as the default size for the bypass?
    Answer :
    Yes, select Additional Function > Common Settings > Stackbypass Standard Setting > On > Irreg sze and enter the size of the paper.
    If the machine is power cycled or the reset button is selected, the irregular paper sze will be retained.
    Note that the maximum paper size is 330 x 483 mm and the minimum paper size is 100 x 148 mm for the bypass.
      • 23010
      I'm familiar with a lot of paper sizes, but have not heard of "F4". What mm measurement is that paper size? =^..^=
        • 16083
          • 23010
          Thanks teckat. I'll add that tidbit to my paper weight spreadsheet.
          So ... since it's 13" long, it will have to feed in the "R" direction. Foolscap Folio should be a perfect match. If that's not an available size option, perhaps it will run as Folio, Government Legal, or C4? =^..^=
          • ZOOTECH
            Senior member of CRS
            • 3375
