Hi All,
Im hearing a grinding noise on my IR 4075 every Start up, and i makes noise until i start making copies.
It grinds every 1-2 seconds.
I tried opening the upper part of the door and make copies. I found out that the Fuser / Fixing Gears are grinding.
Here's the picture of Fuser / Fixing Gears, White on the right part of the biggest gear (in contact with main gear) shows friction damage.
Here's the Picture of the gear the drives the fuser, also shows friction damages.
I tried removing the Fuser / Fixing Gears and clean it. and it makes the same noise.
Thanks for your help.
