Canon IR 4075 ir 3045 grinding Noise
  • Brian8506
    • 1664
    Re: Canon IR 4075 ir 3045 grinding Noise
    Replace the fuser drive on the frame
      Originally posted by gernah
      Sir may akinto ako na ad3880 ang problema niya right paper jam ayaw ma wala.anong dapat kong gawin para ma wala thank you
      1) please in English
      2)
      08-24-2015 #12
      hugohug
      Originally Posted by daniboi
      I think I'm one of them, I run 6,000 to 10,000 copies a day normally, and 3570 can't beat the volume especially on peak days of the month. That's why I have to get a faster machine like IR5000. I'm new to both of these, and I'm hungry to learn fast about these machines.
      By the way, I'm also in need of Riso technician, I got RN 2235ui can you recommend one, I'll appreciate if you do.
      Dont know any riso tech.
      i will advise you to buy Akinto AD3880 120PPM 10x14 B4 image size, 90k 12mo zero interest (7500/mo) with free 12 bottles of ink and 2 masters. lifetime service warranty.
      RN2235ui only produce up to legal size. with the same speed. the only advantage of riso is cheap consumables. akinto also have compatibles just check the net.
      3) Please note the DATE of the posts.
