Canon ir8500 flying paper
  • mramlawi
    • Jul 2011
    • 838
    Dear all,
    i have a canon ir8500 which is working fine after 50 copies on 2 sided the paper flying and jaming before entering the heater ,that my client describion but i hear too much abt the probem , and i heard also suggestions from mates it could be transfer corna problem or hv-pcb ,any one face like this problem also some one told me i can change the value of sp on the servicd mode is thats right ?
    Distinguished road makes you jewel in rough
    • 16083
    Re: Canon ir8500 flying paper
    Originally posted by mramlawi
    Dear all,
    Flying ?
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Inspect transport, delivery anti-adhesion and separation fan.
      • mramlawi
        • Jul 2011
        • 838
        What do u mean in transport and anti adhesion
        The problem happened on b4 and a3 2 sided, on a4 its not jaming also i removed the pre transfer,same problem and checked the bios resestance its giveing me 10k on voltmeter
        • vigour
          • Aug 2010
          • 1038
          Check transport FAN, Delivery FAN, and Separation FAN.
          Change the transfer/separation wires
          You may have to change the Trans/Sep corona assembly. They cause problems after about 1 million
          Yes you can vary the Separation current in software,
          If nothing works, HVT may be weak
          • zoraldinho
            • Mar 2008
            • 5015
            Originally posted by teckat
            Flying ?
            Close the window
            • mramlawi
              • Jul 2011
              • 838
              thanks , i full cleaned the machine fan and still jaming on the 2 sided the jam code is 020A on A3 and 0110 A4 101A4 20E A4 drawers .
              • vigour
                • Aug 2010
                • 1038
                I have only seen transport fan problems on IR550/600,
                you cleaned the fan, are you sure it is spinning, or fast enough.
                I gave you a bunch of other solutions
                  • 16083
                  duplex deflector😭
                  • mramlawi
                    • Jul 2011
                    • 838
                    duplex deflector😭
                    i changed the duplex also , and i full clean the machine fans and all the clutchs inside the machine and unit 1 and changed the high voltage board ,and after a long time trying seems that problem solved when i cleaned the clutch of drawer 3 and 4 i concluded it was delaying problem and now im testing it till now its not jaming
                      • 16083
                      why didn't u deal with clutches in the first place
                      if draw 3 & 4 were the only areas~~~~~~~~~~~~~
                      problem happened on b4 and a3 2 sided, on a4 its not jamming
