Is it possible that there is a problem with the ribbon cables?
When i pull out the cables from the mainboard, i get exactly the same problem and error.
Probably microcracks on the bended places?
(see previous post for movie)
I have read that someone had the same error and replaced the cables wich solved the problem.
Micro cracks can cause numerous problems and intermittent random error codes.
Using the Flexible Flat Cable Checker (FCC Checker) would be a good idea to find out about the condition of the Flex Cable. Flexible Flat Cable Checker IPF Series.pdf
[ATTACH]30509[/ATTACH]
It seems you need 2 of those FCC Checkers to perform the test.
Is there a way to test it whit 1 FCC Checker?
Still waiting for Canon tech but i have in the meantime a question.
WHat does the blue handle on the carriage do. If i move this, i dont see any moving parts.
The axis underneath turns probably with a concentric wheel that moves the head up or down.
Moving the blue handle does not make any change in movement of the axis.
How is this determined that the engine sees how to adjust the printhead acording to the setting of the blue handle?
Slant adjustment handle*
The tilting of the head is adjusted with the lever.
Chapter 2_ 2-22 in manual.
Chapter 1
For fine adjust slant of rules lines.
Read your manual, it explains your operations with description.
I know this, i have read abouth the adjustment of the head.
But i dont see any parts moving, the handle just goes up or down.
I would understand if there is some movement of the head while adjusting the lever, but it does nothing.
Maybe there is something broken, the handle just moves idle.
Regards,
Roverius.
Hi Roverious,
There should be some movement, it only moves up and down a very small amount, but yes it is meant to move ever so slightly. Maybe something wasn't replaced properly when the carriage assy was removed.
The liquid in your purge unit is normal, its meant to keep the head lubed up so the ink doesn't dry up and block the nozzles in the printhead.
Cheers,
Thanks SAZ911
It came to my attention that nothing moved at all, even before i have taken out the printhead.
Even a small movement should be noticable, but in this case it does not.
Thats why i think there must be something broken and (maybe) could be the cause of the error.
Is there somewhere a detailed video of such a carriage? (i will search also)
