IRAC2030 Not Booting Up - Please Wait
  • copier tech
    • 8174
    [Misc] IRAC2030 Not Booting Up - Please Wait
    Hi all,
    I've got an irac2030 that is stuck at the boot up screen (see pic) & I cant get into service mode.
    I booted up in safe mode & reinstalled the firmware from a usb drive, but after this installed & the machine restarted it is still stuck on the start up screen.
    I removed & cleaned the memory, re seated the connections, no luck.
    I'm thinking the HDD has failed, any ideas????
  • teckat
    • 16083
    Re: IRAC2030 Not Booting Up - Please Wait
    [ATTACH=CONFIG]30460[/ATTACH]
    Hi all,
    Replace the DIMMS
    ADVANCE C2030 / C2020
    Machine is stuck in wait at power on. Rebooting the machine will not clear the wait screen.
    On the Main controller 1 there are two dimms, re_seating the dimm resolved the lock up of the machine being stuck in wait.
    The part number for the dimm is FK2-8341-000
    Also re_seat the dimms located on Main Controller 2 if needed.
    The part number for the dimm is FM4-3146-000 or replace dimms if needed.
    • copier tech
      • 8174
      Thanks for the info, we've got a spare 2030 i'll remove the DIMS from it to test.
      If I do end up swapping the HDD will the customer loose their addressbook?
        No the address book is stored on the main controller.
