Distorted image in the side 2, when duplexing, on iRADVC 9060.
  • Ingranaggio_rotto
    • Oct 2010
    • 275
    I'm still here.....
    I have this problem: on a iRADVC 9060, when duplexing, the image of side 2 it's distorted respect at the image of side 1.
    And the defect is known especially in the tail (about 2 mm in the A3 size ).
    I found a service bulletin but it show the fault only for small sizes.
    Suggestions ?
    Thank !
  • Iowatech
    Not a service manager
    • 3930
    Re: Distorted image in the side 2, when duplexing, on iRADVC 9060.
    We can't see your machine or what it is doing, so maybe share some examples, please?
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Distorted? You mean like offset(indented)? Did you try to set first and the other side with settings in user mode?
      • Ingranaggio_rotto
        • Oct 2010
        • 275
        An example: the print a rectangle in side 1 of the sheet and side 2 of same sheet. Size of print: A3.
        The head of the image (considering the output of the paper), both on the first and on the second side is aligned!
        In the tail of the image, in the side 2, it is deflected to the side user by 2 mm compared to the 1 side (which remains perfectly aligned with the edge of the sheet).
        • _SuabE_
          • Jan 2008
          • 108
          You mean during duplex printing the trailing edge of the image is delay for about 2mm, try to clean the duplex feed rollers and reg. rollers using WD40. During the feed of the 2 page there is a delay on the paper or the paper moves 2 mm to the left side during pick up situation in the duplexing unit.
          Regards
          sigpic
          Senior Technician Specialist
          A+; Network+
          Copier Brand handled: Canon, Lanier, Konica Minolta, Sharp, Ricoh, Kyocera Mita, Nashuatech, Ollivetti, Toshiba
          Printer Handled: Canon, HP, Epson, Brother, Samsung
          Duplicators: Risograph, Duplo
          • zoraldinho
            • Mar 2008
            • 5015
            Do not use WD-40 on plastic or rubber! WD-40 contains petroleum distillates (paint thinner).
            When Should I Not Use WD-40?
