error code e000000 in ir 2520
  • GODLOVE
    • May 2015
    • 5
    Hi everybody!
    Thank you for accepting me here.
    I am Godlove from Tanzania, East Africa.
    I have may Canon ir 2520 that when i tray to shoot on it gives a error message above (error code e000000 in ir 2520) if any one can help me to find solution. I have triad to replace a new HVT it still does the same
  • _SuabE_
    • Jan 2008
    • 108
    Re: error code e000000 in ir 2520
    Originally posted by GODLOVE
    Hi everybody!
    It is fixing error just reset it from the service mode.
    Cheers
    sigpic
    Senior Technician Specialist
    A+; Network+
    Copier Brand handled: Canon, Lanier, Konica Minolta, Sharp, Ricoh, Kyocera Mita, Nashuatech, Ollivetti, Toshiba
    Printer Handled: Canon, HP, Epson, Brother, Samsung
    Duplicators: Risograph, Duplo
    • GODLOVE
      • May 2015
      • 5
      Cheers
      Thank you for your respond. Well i did try to clear it bay entering Service Mode >CLEAR>ENGIN>ERRCLR enter Service Mode >CLEAR>ENGIN>ERRCLR and finally power cycle the machine. It Cycle for a while then stop and turn again to the previously state of error e000000. If i may ask if is something to do with the blue n red cables on the Engine control er Circuits? Because i changed all to a new Control circuits or is something else ?
      • GODLOVE
        • May 2015
        • 5
        Hello pleas help me with this problem. and if possible someone send an electrical wiring manual of this machinery
        • GODLOVE
          • May 2015
          • 5
          Helow! I hope someone is goner help me with a solution to my Machinery
          I m still waiting
          Thank you Technical Friends
          • doktor
            • 214
            Replace fixing unit end reset than try with old unit.
              • 8195
              If you got the E0000 error AFTER you replaced any boards & you can't reset it in service mode I would suggest that you have a loose connection somewhere, go back & check the work you did.
              If all looks good then may just be a coincidence & you'll need to replace the fixing film ass'y
              • GODLOVE
                • May 2015
                • 5
                Thank you friends! I have removed older fixing and replace another one. Then shoot On the machinery started and engine rotate on its normal way. There after it change onto e000246. What do i do?
                • cdtw9803
                  • Aug 2009
                  • 51
                  E246 means that AC power supply is not normal or bad power supply pcb.
