iRC5185 color misalignment
  • bbaker73
    • Oct 2013
    • 21
    I have two iRC5185's and two i use for spare parts. Quite some time ago, one started having color alignment issues. It's secondary machine so we just used if for B&W until I could get to it.
    I swapped the ITU assembly with one from a spare machine and it prints the EXACT same misalignment on the PG6 and PG10. I removed and cleaned the lenses on the pattern reader unit. What else could it be?
    I'm not a tech so I know I'm limited, but I can swap parts/clean.
    Paper is loaded portrait, so this would be the sub-scanning direction, which is why I thought it would be the ITU.
  • teckat
    • 16083
    Re: iRC5185 color misalignment
    [ATTACH=CONFIG]30722[/ATTACH]
    First try>
    in Service mode Level 2 > Copier > Function > Clear > REG-CLR.
    Next power cycle the copier. Now run a Quick adjust and then check with a PG 10.
    SERVICE MODE Level 1
    1) Press Additional Functions Key (*) > release
    2) Press # 2 & 8 keys at the same time> release
    3) Press Additional Functions Key (*) again-
    To go to Service Mode Level 2, > First go to Service Mode Level 1 and then:
    1) Press Additional Functions Key (*)>release
    2) Press #2 Key > your in
    iRC5180_Color_Shift_Prevention _&_Correction.pdf
    • bbaker73
      • Oct 2013
      • 21
      Originally posted by teckat
      First try>
      [ATTACH]30723[/ATTACH]
      Wow. Thanks Teckat. REG-CLR fixed it. There is still some minuscule space between the black and yellow, and the cyan and magenta if you zoom in (not a great scan) but I think it will be workable. Much thanks.
      • teckat
        • 16083
        The Dude.jpgWELCOME
        should be ok !!!
        • Toner Boy
          • Aug 2007
          • 366
          Been through this (with some help w/TCat), if it comes back the ITU should be suspected still. I think it's related to the secondary internal roller (in ITU) that pushes transfer belt against the secondary transfer external roller (final transfer) but swapping whole belt unit fixed issue in 3 machines when other attempts failed. Swapping just the belt and cleaning etc did not.
