ir4570 cassette problem
  • Field Man
    • Sep 2015
    • 7
    hi good day to you or what ever time you are reading this. pls can someone help me out. I'm working on a canon IR4570 which is having problems with the first Cassette. when i set the paper guide to a particular size, load the papers, select the paper size and close the cassette. the screen still display load paper. pls help me out. thanks and waiting
  • teckat
    • 16083
    Re: ir4570 cassette problem
    Can be caused by the Lifter Plate or the Lifter Gear in the paper cassette being damaged or bent.
    Check
    The part number for the Lifter Plate is FB6-3486-000.
    • sharptech1
      • Oct 2011
      • 163
      reseat pickup roller. don't know why but this works for me
      • Field Man
        • Sep 2015
        • 7
        thanks the problem was the coil at the cassette. I open and saw some toner all over the coil, so I removed the coil and blow it up. after that putting everything back. the ir4570 cassette problem was solved. thanks to all
        • Jake2o
          • Dec 2007
          • 325
          "so I removed the coil and blow it up"
          I get the same feeling with Canon printers sometimes LOL
          • teckat
            • 16083
            COIL_:~ ?
              Originally posted by teckat
              COIL_:~ ?
              Maybe soleniod?
              • zoraldinho
                teacher-guide-expert-guru
                • Mar 2008
                • 5015
                Probably solenoid.
