Ir adv 8105 display black
  • eurokris
    • 120
    [Dead] Ir adv 8105 display black
    Hi friend.
    Ir adv 8105 display black. Only yellow is on.
    but is running. How to solve this problem.
    Thanks.
    • 16083
    Re: Ir adv 8105 display black
    Originally posted by eurokris
    Hi friend.
    Thanks.
    The LCD Display on the Control Panel is black but the green power LED on the Control Panel is lit.
    Also, the machine cycles when the main power is applied and the machine tries to reboot.
    The network cable is unplugged from the machine. Main Controller #1 PCB was reseated to Main Controller #2 PCB. DRAM memory for both main controller pcbs were reseated.
    3.3 VDC and 12 VDC is present at J4 for Main Controller #2 PCB. Download Mode does not appear when keys 2 and 8 are held down at power on.
    Error code E602 does not appear on the LCD Display of the Control Panel at power on when the Hard Drive is unplugged from Main Controller #2 PCB.
    For this case, replacing Main Controller 1 PCB resolved the service issue of the LCD Display on the Control Panel being black. The part number for the Main Controller 1 PCB is as follows:
    FM4-5300-010 for the iR-ADV 6055
    FM4-5301-010 for the iR-ADV 6065
    FM4-5302-010 for the iR-ADV 6075
    FM4-5303-010 for the iR-ADV 8085
    FM4-5304-010 for the iR-ADV 8095
    FM4-5305-010 for the iR-ADV 8105
    The back light on the control panel LCD display is off. If a flashlight is shown on the LCD, you can see that the information is displayed.
    It was noted that print jobs would work correctly.
    Replacing the Inverter PCB Assembly (FM3-9994-000) resolved the problem. The following image shows the location of the Inverter PCB Assembly within the Upright Control Panel Assembly.
    • niyaskarimba
      • Sep 2014
      • 110
      At the start up machine is running as usual and it reboots automatically,When we remove the HDD the Error E602 appears.
      what i need to do for resolving this issue.
        • 16083
        u cant' run the printer without a HDD that is why u get a E602 = no HDD = NO FIRMWARE= NO OPERATING SYSTEM
        are u a tech ?? if so u should have that general knowledge-----
        check your memory----remove >clean ends & re-seat
        also check your connections on Main Pcb
        Machine boots up fine and comes to the ready state to be used.
        The machine intermittently will shut off.
        When the machine would suddenly shut off, it was found that 12 VDC was missing at connector J4 of the Main Controller #2 PCB but 3.3 VDC was present at connector J4.
        Going to connector J511 on the Relay PCB (output from the 12 Volt DC Power Supply), 12 VDC is not present at pins 3, 4, 5 and pin 6 but pin 1 of J511 (Remote signal) does have 2 to 3 VDC present for turning the 12 Volt DC Power Supply On.
        Refer to the following illustration of the circuit diagram.
        Replacing the 12 Volt DC Power Supply in the Power Cord Terminal Assembly resolved the service issue of the machine shutting off / shutting down when banging something to hard on the machine.
        • niyaskarimba
          • Sep 2014
          • 110
          "Error code E602 does not appear on the LCD Display of the Control Panel at power on when the Hard Drive is unplugged from Main Controller #2 PCB.
          For this case, replacing Main Controller 1 PCB resolved the service issue of the LCD Display on the Control Panel being black. The part number for the Main Controller 1 PCB is as follows: "
          This portion is from your previous thread,Thats why i mentioned,when we remove HDD 602 error appears.
          Already removed and reseated memory and all connections from the main pcb
          I will check the power supply voltages
          • niyaskarimba
            • Sep 2014
            • 110
            Problem solved by replacing new HDD.
            Thank you so much for all your supports.
            • usateam
              Hi friend.
              Thanks.
              i have the same problem at one of my client on imagepres 1110. display black only the power green light is on. it runs normally.
              • wcanonw
                • Aug 2014
                • 404
                Hi, how did you give it a solution?
                  dead thread
                  totally diff machine.
                  should have started your own thread
