CANON NP 6551 /Jamming
  • cucuklotz
    • Mar 2007
    • 611
    Hi
    I'm getting a grinding noise coming from conveyor belt area and jamming right before fuser unit.Havnt seen many of these,Any help
    will help a lot.
    Thanks Andy
    • 23008
    Re: CANON NP 6551 /Jamming
    What jam codes?
    If it's jamming 010C, the odds are that your fuser drive clutch is slipping. The fuser slows down and stalls, and the paper ends up flipped over in the bite of the fuser, with the next page sitting on top of that. The clutch can be cleaned and re-greased with IBM23 grease. Keep in mind that this is quite an old machine, and that clutch may absolutely need replacing. Grease the new clutch like you did the old one. =^..^=
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Open front door an make door switch contact.Turn on the printer,wait to warm up and inspect fixing roller if uniformly rotate.I suspect fixing gear.
      Definetely post jame code!
      make the standard procedure
      -Is the height of the paper guide
      correct?
      -Is the cleaning belt taken up
      correctly?
      -Are the external delivery sensor
      (PS10) and the fixing assembly
      outlet sensor (PS47) normal?
      -Is the delivery paper deflecting
      plate oriented in the direction of
      delivery?
      -Does the delivery roller move
      smoothly?
      • cucuklotz
        • Mar 2007
        • 611
        Hi
        Sorry doing about late post.Thank you for all the help,I was doing this call as subcontractor for another company.The customer never went ahead with the work and decided to get new machine,THANKS ANDY
