Big problem!!!
  • Ronald Canon
    • Dec 2011
    • 30
    Big problem!!!
    Hello everybody, i have an issue with an IPR C1...
    IMG_20151027_115549.jpgIMG_20151027_125508.jpgIMG_20151027_125512.jpgIMG_20151027_125516.jpgIMG_20151027_125520.jpg
    It could be any color, sometimes two or more of them. Thanks for the help.
  • jhoncrema
    • Jul 2014
    • 8
    Re: Big problem!!!
    Check the drum maybe it's has
    electrical leakage
    Enviado desde mi iPhone utilizando Tapatalk
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Re: Big problem!!!
      what have you done so far?
      What did you check?
      How many prints have printer,itb,developers?
      Eny errors in the past?
      Values?
      • Dutchman
        • Jan 2011
        • 58
        Re: Big problem!!!
        [ATTACH=CONFIG]31082[/ATTACH][ATTACH=CONFIG]31083[/ATTACH][ATTACH=CONFIG]31084[/ATTACH][ATTACH=CONFIG]31085[/ATTACH][ATTACH=CONFIG]31086[/ATTACH]
        The inside of your drum developing area the P-Kit is dirty and causes the machine to arc. you need to take out all the developers and vac out the area especially the dev that has dropped to the bottom of the P-Kit.
        I hope this helps.
        • charm5496
          • 2387
          Re: Big problem!!!
          or your drum is worn on the edges causing an arcing as well. I would get a drum, drum cleaning balde and new side felts for sure.
          • Ricardo25
            • Feb 2013
            • 9
            Re: Big problem!!!
            limpieza de revelados y carga primaria.
