Canon IRA C2020
  • Reed
    • Feb 2011
    • 259
    Canon IRA C2020
    Went to look at this machine. It has a print or fax job in memory and when it tries to print the page the paper feeds to the registration roller then eventually comes up with an E315-00d code (abnormality of image data) I took out the SDRAM and cleaned it. Any other suggestions? If I need to replace the hard drive do I need to replace the HDD or reload the programming? If so, is it fairly straight forward and can someone help me get it. Thanks in advance.
  • dan7777
    • Dec 2012
    • 680
    Re: Canon IRA C2020
    I did not see a E315-00d in the service manual. It is not straight forward and the usb software files are very large. Service manual says HD, main controller 2 and others. Updating the sofware is the easiest to try. Did not see much on that model and that code E315.
    • Reed
      • Feb 2011
      • 259
      Re: Canon IRA C2020
      Technically it is a E000315-00d. I left of the zereos. Seems almost all canon errors start off with zereos
      Sent from my SGH-M919 using Tapatalk
      • dan7777
        • Dec 2012
        • 680
        Re: Canon IRA C2020
        You are right. I missed it the first time. I did not know if you had a service manual or not.
        E315 000d 00 Title Image process device errorDescription JBIG decode errorRemedy 1. Delete the current job2. Turn OFF and then ON the main power3. Check connection of Main Controller PCB 24. Replace the DDR-SDRAM, the HDD and Main Controller
        PCB 2 at the same time
