IRC 4580i Automatically restarting
  • gorganite
    • Apr 2015
    • 14
    [Dead] IRC 4580i Automatically restarting
    Any idea what could be happened with the machine as it behaving strange, its automatically restarting itself often since last two days.
    regards,
  • teckat
    • 16083
    Re: IRC 4580i Automatically restarting
    regards,
    CHECK --fixing unit & temps
    also check your outlet for proper voltages & proper ground between > GD to NEUTRAL=0v +/- 0.5v max
    does printer just go into warm-up & recycle
    machine would intermittently reboot or cycle off and on through out the day.
    Setting all WSD Print settings to off may resolvethe issue.
    Additional Functions>System Settings>Network Settings>TCP/IP Settings>WSD Print settings>Use WSD to off
    Additional Functions>System Settings>Network Settings>TCP/IP Settings>WSD Print settings>Use WSD Browsing to off
    Additional Functions>System Settings>Network Settings>TCP/IP Settings>WSD Print settings>Use Multi Cast Discovery to off
    could also mean your HDD is crapping out.
    • Taggerung08
      • Sep 2014
      • 60
      regards,
      I would be suspicious of the power supply to the machine. Check the voltages as Teckat suggested and definitely be more specific about when the machine powers off.
      When it turns on, do you see the warmup screen? Does it boot to the main menu? Do you hear the engine warming up? Is the fuser getting warm at all? Does the screen stay black and just reboot? Does the green power light turn on and off?
      • gorganite
        • Apr 2015
        • 14
        Dear All,
        I Have found that the RAM were faulty due to that it was continuously rebooting again and again, engine starts well and when screen show canon logo with "wait" below the logo, machine restarts itself.
        any how as per your suggestions i have replaced the complete power supply, all the communication card from the mother board but its only work with RAM replacement.
        Thanks for the help.
        regards,
