Canon C1 error E0025
  • faxadipan
    • Jan 2015
    • 9
    [Error Code] Canon C1 error E0025
    Hello,
    I do have Canon C1 and CanonC1 plus in the same location.
    I do have a problem with E0025 Error.
    When I am trying to use SPLY-Colour CanonC1 I have the same error for each colour.
    E0025-0102
    E0025-0202
    E0025-0302
    E0025-0402
    On C1 plus I do have only for yellow .
    The error appears when I am printing
    I checked mechanically the toner supply system and it seems Ok.
    The supplyind motors are Ok also.
    Please help me with more information.
  • jhoncrema
    • Jul 2014
    • 8
    Re: Canon C1 error E0025
    There's a board in right door check this. Sorry my English isn't very well.
    Enviado desde mi iPhone utilizando Tapatalk
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Did you push back shutter lever?
      • faxadipan
        • Jan 2015
        • 9
        [ATTACH=CONFIG]31157[/ATTACH]
        Yes the lever is in the right possition.
        • zoraldinho
          • Mar 2008
          • 5015
          Poor contact! Inspect connectors.We talk about this problem here: http://www.copytechnet.com/forums/ca...highlight=E025
          • jhoncrema
            • Jul 2014
            • 8
            Check the board in the right door
            • teckat
              • 16083
              Check your density in service mode for all colors (Display > DENS-Y/M/C/BK
              if all -negative numbers------------- machine will try to add toner---if the auger to the developing assembly is clogged / it will prevent the toner from getting there.
              you may need to clean and unclog the supply augers
              following image shows the location of the augers for all colors.
