Cleaning web roller problem
  • 813200217
    • Oct 2014
    • 51
    Anyone can help me?
    ir6570 ; error e014
    after i check it
    the problem was
    Cleaning web roller get into the lower pressure roll
    how to fix it?
  • teckat
    • 16083
    Re: Cleaning web roller problem
    Originally posted by 813200217
    Anyone can help me?
    ir6570 ; error e014
    after i check it
    the problem was
    [ATTACH=CONFIG]31155[/ATTACH]
    how to fix it?
    Make sure the web take up is installed properly.
    Check your manual
    • 813200217
      • Oct 2014
      • 51
      thanks
      already fix it
      not me but by my technician
      teckat
      in service menu, it said that
      "cleaning blade is low"
      what is that?
      • copier tech
        • 8169
        Cleaning blade is the drum blade, replace it or reverse it every 500k
        The web can be pulled into the fuser unit if the upper fuser roller is excessively worn also the one way clutches in the web drive can fail causing the same issue.
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5015
          Oneway clutch,gear,fake web,improperly installed web....
          There is an option to adjust web speed in service mode.
          • 813200217
            • Oct 2014
            • 51
            can you tell?
            • zoraldinho
              • Mar 2008
              • 5015
              can you tell?
              When copies/prints are made after the message has been issued, the machine starts to monitor the count (COPIER>COUNTER>MISC>FIX-WEB;
              fixing web counter). When the count reaches '2000' (in terms of A4, 3000 copies/prints), the machine issues error code 'E005'.
              SERVICE MODE:
              COPIER>OPTION>USER>WEB-DISP
              Use it to enable/disable the web length warning message:
              0: off (however, the message will be indicated on the service mode screen)
              1: on (default)
              If you have replaced the fixing web, be sure to reset the following counter readings to '0':
              - COPIER>COUNTER>MISC>FIX-WEB
              fixing web counter
              COPIER>COUNTER>DRBL-1>FX-WEB
              COPIER>OPTION>BODY>CBLTINVL
              Use it to set the number of times the fixing web solenoid goes on.
              Use it if an image fault occurs as a result of soiling on the pressure roller.
              0: normal (default)
              1: twice as often as normal
              Don't mess with service mode!
