Canon c2880 clean glass
  • dustzona
    • Mar 2015
    • 83
    Is there a way to adjust or turn off the[ clean glass ] message. I am guessing that it's on because of some wear on the scanner glass. Next step replace the glass
  • dan7777
    • Dec 2012
    • 680
    Re: Canon c2880 clean glass
    There is. Usually in user settings to turn off completly. You can turn down sensitivity at DF-DFTSL1 and L2. The settings are in service mode in different places on different models. I turn a lot of mine off or down to 100 or 80. Not something that has worked well I know of. We turn ours down to 125 on new machine setup. I wish I could tell you exactly where those settings are, but maybe some one else can.
    • copier tech
      • 8101
      Dan is correct,
      Adjust the following in Service Mode:
      Copier>Option>IMG-RDR>DFDST-L1* and DFDST-L2*
      For backside dust detection adjust Copier>Option>IMG-RDR>DF2DST-L1 and L2.
      DFDST-L1
      Default value 200
      Display/adj/set range 0 to 255
      0: OFF
      Black lines may appear on the image if there is dust. With dust detection correction control, the image is corrected to prevent black lines once dust is detected.
      DFDST-L2
      0: OFF
      Default value 200
      *Adjust these values to a lower number to reduce the frequency of this message. Lowering the values reduces the circuit sensitivity.
      NOTE: You must power cycle the machine for a value change to take effect
      • dustzona
        • Mar 2015
        • 83
        thanks for the knowledge . I'll give it a try
        • duwaynebrooks
          • Aug 2015
          • 41
          Clean glass display option.
          Additional functions
          Common settings
          7/8 Cleaning display for the original scanning area (on)
