canon ir7200 jam 109 and copy shrinking
  • ikbal
    • Apr 2014
    • 22
    [Jamming] canon ir7200 jam 109 and copy shrinking
    I has an engine problem canon ir7200 issued a jam error code 109 , and one more problem in the copy that is shrinking , beg its support brother
    indonesian: Saya memiliki masalah mesin canon ir7200 mengeluarkan kode kesalahan jam 109 , dan satu lagi masalah dalam salinan yang menyusut , mohon saudara dukungannya
    • 22999
    Re: canon ir7200 jam 109 and copy shrinking
    Shrinking by how much? Both X & Y direction? Just X?, Just Y? =^..^=
    • ikbal
      • Apr 2014
      • 22
      and jam code 109?????????
      • ikbal
        • Apr 2014
        • 22
        Just X shrinking
          • 22999
          I would:
          1) clean and lubricate the registration roller bushings
          2) check rubber registration roller for even diameter. The rubber can come unglued from the core shaft.
          3) clean or replace registration clutch.
          The last is the most likely, but it's a good idea to check the others also. =^..^=
